2005 6.0 tranny filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-24-2010, 04:18 AM Thread Starter
OrthoPro
AaronForbes's Avatar
I am going to be servicing my auto trans on my '05 F350.
What is my tranny filter going to run me thru NAPA or the dealership including the tranny oil?
A. Forbes
AaronForbes is offline
post #2 of 12 (permalink) Old 03-24-2010, 04:20 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: 2005 6.0 tranny filter
The one in the pan is really for catastrophic failure. The one on the frame up front is the important one. The filter is around 30 dollars. The fluid roughly 5 dollars a quart.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 12 (permalink) Old 03-24-2010, 04:23 AM
your mom
RMPowerstroke's Avatar
think about amsoil first off. also really is a preff i wouldnt run a napa filter i would run oem and oem fluid and plan on spending a bill atleast
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
post #4 of 12 (permalink) Old 03-24-2010, 04:28 AM
PETE ENGR PSD
I just got to OEM filters I think it was like around $40 a piece at the stealership. They look like a roll of toilet paper for a smurf and I wanna think I used ~8-10 quarts to get it back to the fill line on the stick?
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #5 of 12 (permalink) Old 03-24-2010, 04:36 AM Thread Starter
OrthoPro
So doesnt the service recommendation call for the toilet roll filter and the one in the pan to be changed out at 60k?
post #6 of 12 (permalink) Old 03-24-2010, 04:52 AM
Captain Negativity!
PSDPlayer's Avatar
Oddly Enough...
The TorqShift automatic
transmission is equipped with a
serviceable external fluid filter
mounted on the frame rail. Refer to
the Scheduled Maintenance Guide
for service intervals.
To replace the transmission filter:
1. Shut off the engine.
2. Unscrew filter housing.
3. Replace filter with a new authorized Motorcraft filter element. Refer to
the Motorcraft part numbers chart in this chapter.
4. Reinstall housing and check transmission fluid level using procedure in
this section.
30k miles...
Change automatic transmission fluid on vehicles
equipped with the Torqshift and 4R100
transmissions. Replace the remote filter element
on the vehicles equipped with the Torqshift
transmission. Inspect automatic
transmission/transaxle fluid level on all other
vehicles, if equipped with dipstick. Consult your
dealer for your particular requirements.
60k miles...
Right out of the 4th printed maintenance schedule for your truck.
Email:
post #7 of 12 (permalink) Old 03-24-2010, 11:34 PM
40 lug nuts
Snake's Avatar
For those of you that don't know Doug, that would be a "no."
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #8 of 12 (permalink) Old 03-27-2010, 01:45 AM
that toliet paper filter up lower front can be a pitfa to get off
turbodieselny is offline
post #9 of 12 (permalink) Old 03-27-2010, 02:31 AM
hillbilly123's Avatar
Just give it a quick zap with an air impact wrench and it comes right off. Have not broken any as of now. I got tired of bending the mounting brackets.
Robert Hicks
2003 F350 CC LB, EGR Delete, Quadzilla xzt, Zoodad Mod, CCV reroute and muffler delete option.
hillbilly123 is offline
post #10 of 12 (permalink) Old 03-29-2010, 03:28 AM Thread Starter
OrthoPro
An FYI, did the internal and external tranny filter, both gas filters too.
Dropping the pan was a piece of cake, just cleaned it and re-installed the internal, simple easy and relatively cheap. External was equally as easy just slightly quicker.
Did find some crud in the bottom of the fuel cell when I removed the top side fuel filter, took the shop vac and sucked it dry and clean, and I did find they prior owner DIDNT use an MotorCraft filter, whether or not the height/width is any different I dont know, maybe the crud by-passed the afternarket one, who knows.
The hardest one was the frame rail filter, and it wasnt that bad, just made my sweater smell like diesel. By far cheaper doing it myself than having the stealership rob me.
