Hydrolocked after injector change. Help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-10-2019, 11:46 PM Thread Starter
Ryan_Glick's Avatar
So this weekend I changed my injectors in my 6.0 powerstroke. I unfortunately do not have the luxury of a two-point lift so I had to do it with the body on. It's not a hard job I've done it plenty of times and I'd say I'm pretty experienced in the job. I changed them out made sure all of the new injectors had new seals on them o'rings that copper seal by the injector tip make sure the injector cups were good and not cracked and installed them like anybody else would. Used the correct torque on everything, blah blah blah. I started up the truck and it sounded really good. I let the truck idle for about 10 to 15 minutes until the coolant and oil temp were at about 140 degrees and 145 degrees. I went out on a drive and I wasn't even out on the road for more than 30 seconds before I was in 4th gear, and I noticed that the truck was not shifting into 5th when it should have. I let off the gas, and noticed that it shifted into v and I heard a very loud ticking coming from the passenger side. before I knew it I had lost pretty much all power, and I was white smoking like a freight train. The truck shut off by itself, and it had a no crank no start. I had heard of the horror stories of trucks hydrolocking after injector change so I towed it back home and started to remove the glow plugs. I saw that it wasn't coolant because the exhaust manifolds were bone dry so I knew I had to be fuel-related. I unplug the fuel pump and took the starter wire and touched it to the battery. Fuel came bursting out of cylinder one but cylinder 3 5 and 7 were okay. I got to wear all of the fuel is out and then started disassembly again. I removed injector one to find that the bottom O ring I think it is white was torn in two and the copper washer on the end of the injector nozzle was gone. I remove the o-ring from the cylinder head and the copper washer from the cylinder head. luckily I had a spare injector that was brand new to put in its place so I put it in put it back together and started it up. Now this time was a little bit different. Before, it sounded very smooth and a lot quieter. Now it said it sounded like it 7.3 and I hear a very faint ticking coming from what it sounds like cylinder one. I've read that you can bend a rod after hydrolocking but it is not very common. The truck runs, but not the best. I haven't taken it out for a drive yet because I'm too scared that it'll blow up again. I don't know what I should do, if I should take it to a shop and have them evaluate it, or just get a whole new valve train. I doubt I'll need a whole new valve train, but it sure would be nice to have. But it could also be a rocker arm tick or a lifter tick. it's very hard to describe the noise because the motor is already noisy to begin with, so I'm not sure where to go. I don't know if I should tear it all back down again, or just leave it be and drive it for a little bit. I've also noticed that it takes about 5 to 10 seconds to start up every time after changing out the injectors. It's almost like it's not holding oil pressure, but I'm not really sure because I've never had this problem. last time I tried to change out my injectors I had an issue changing out number seven. so I just put the old ones back in, and had no problem with it starting up again. Any help is appreciated. Thank you.
Ryan_Glick is offline
post #2 of 3 (permalink) Old 04-11-2019, 01:28 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Hydrolocked after injector change. Help!!
That injector you put in #1 might be bad. That may be a misfire you're hearing. A contribution test would tell you. It will take a bit of driving to get all the air out of the oil rails. Thats why it takes a little longer to start.
I would advise taking it to a shop that knows powerstrokes.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 5.8L XLT Tan leather interior. Soon to be swapped onto a 6.0 frame.
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 3 (permalink) Old 04-11-2019, 11:36 AM
Master BS'er
jamiesaun's Avatar
Take the valve cover off and have a look. If it's bent, the rocker will have more play than the others. Probably gonna have to spin the engine over by hand until a few of them are loose to check for it. A stethoscope with a medal rod wouldn't be a bad idea.
Hydrolock can damage more than just a push rod. It could damage pistons, valves, connecting rods, heads, rockers etc. Take a look and see what ya got.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is online now
Similar Threads
Hydrolocked my truck please help me! Lg33 6.4L Power Stroke - Technical Info 6 07-19-2013 01:08 PM
6.0 Hydrolocked need help please. Enthusiast 6.0L Power Stroke Technical Info 3 07-10-2012 04:19 PM
Hydrolocked PLUS RHCDIESEL 6.0L Power Stroke Technical Info 2 05-06-2010 01:49 AM
hydrolocked RHCDIESEL 6.0L Power Stroke - Aftermarket & Performance 13 05-02-2010 06:04 AM
hydrolocked? frashdog 7.3L Power Stroke Technical Info 12 07-15-2009 12:51 AM
