04 F350 4x4 4door SC cab long box which is best lift pump? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-12-2019, 12:22 AM Thread Starter
Which is best lift fuel pump an are they plug an play OEM Airdog 2 4gen looks like is some what plug an play. Do any have advice on this don't have lots of $ am disabled veteran an on limited income but stock pump is going out an trying to keep my injectors running as long as possible. Thank you. First time asking for your all help hope I doing it right.
DWATSON is offline
post #2 of 4 (permalink) Old 04-30-2019, 04:00 AM
Xcursion813's Avatar
I was going to go with an Airdog 4G but came across some discussions about using a 6.7l fuel pump. The 6.7l has more than enough power pushing up to 120psi. You have to piece it together pump, hose, relay harness, quick connects but It’s a fraction of the cost and readily available at any parts store if it ever failed unlike the aftermarket brands. Search 6.7l 6.0l fuel Pump swap.
Xcursion813 is offline
post #3 of 4 (permalink) Old 05-16-2019, 03:28 AM
Some pics of the process
File Type: jpeg 79D9EEF5-3696-43A1-BBBD-41EDAEFE274F_1557977254233.jpeg (2.56 MB, 11 views)
File Type: jpeg 563C287F-E213-4CED-856A-B4ED49DA9344_1557977288279.jpeg (1.97 MB, 9 views)
File Type: jpeg F8FD36AF-3385-4437-BA54-7235C01C0480_1557977300475.jpeg (3.19 MB, 10 views)
File Type: jpeg DF977479-991C-493B-9D9A-2CC9175DA2F5_1557977314140.jpeg (2.96 MB, 7 views)
File Type: jpeg 83A04DD5-D4DF-4823-98A6-6802F695C482_1557977326457.jpeg (1.97 MB, 9 views)
post #4 of 4 (permalink) Old 05-16-2019, 03:34 AM
I also did a custom fuel bowl delete, regulated return and coolant recirculating set up with SS Lines, AN fittings for a fraction of the cost.
File Type: jpeg 874338F4-9CA2-4E6E-AF4A-0DE04C24AD0F_1557977602277.jpeg (3.33 MB, 9 views)
File Type: jpeg E0F8EDD5-0B77-40AD-8092-2D5AF33D74FC_1557977613909.jpeg (2.92 MB, 7 views)
File Type: jpeg B4CCFE48-A446-4A24-BCF1-DABD69A42D79_1557977637842.jpeg (3.25 MB, 11 views)
File Type: jpeg E488AC56-F054-4D2D-863E-BD18C4B3BC94_1557977670046.jpeg (3.04 MB, 9 views)
