6.0 banjo bolt upgrade: 6.4 or aftermarket? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-18-2019, 10:03 PM Thread Starter
Garage
Passenger side banjo bolt is leaking fuel, so it is time to replace them. Gonna replace them both for good measure, and because the dealer only knew they had been upgraded in the past, and not specifically what kind they were.
My question is about which ones I should get. I know slapping the 6.4 bolts in was a pretty common mod in the past, but are there any better options? Has any company come out with some nice aftermarket bolts made especially for 6.0s?
Ive been eyeing up these bolts from RiffRaff that advertise "highest flow possible" https://www.riffraffdiesel.com/riffr...olt-6-0l-6-4l/
is "highest flow possible" always a good thing? Would extremely high flow increase fuel consumption?
2004 F250 6.0 XLT
"bullet proof"
with ARP studs
sinister diesel oil cooler
EGR delete
MBRP straight pipe exhaust
schober60 is offline
post #2 of 4 (permalink) Old 02-19-2019, 01:00 PM
Weatherlite's Avatar
Garage
Re: 6.0 banjo bolt upgrade: 6.4 or aftermarket?
Unless you install some ridiculously large injectors and upgrade your engine beyond the realm of mere mortals, you will have more than ample flow from the 6.4 bolts. And no, you won't consume more fuel just because of the higher flow rating....they just mean that if the need is there they can flow more, but they will never flow more than what is actually being used by the engine.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 4 (permalink) Old 02-20-2019, 05:47 AM Thread Starter
Garage
is there any reason not to get the riff raff ones? Like is this one of those cases where OEM really does it right (with the 6.4 that is)? Otherwise, if there is no downside to the riffraff I would be willingly to spend an extra 20 bucks to support a company that I trust.
2004 F250 6.0 XLT
"bullet proof"
with ARP studs
EGR delete
post #4 of 4 (permalink) Old 02-21-2019, 03:28 PM
Garage
No reason other than you're paying for more flow than you could ever use. lol But, if you don't mind supporting them for a great product, go for it!
2004 Excursion 6.0
Similar Threads
banjo bolt in the back of the pump 6.9turbocharged 1994-1997 Power Stroke Technical Info 12 02-25-2011 09:33 PM
Banjo Bolt Mod jrmmustang 6.0L Power Stroke - Aftermarket & Performance 13 12-06-2010 11:38 AM
Banjo Bolt Install (Help) majorleaguebass 6.0L Power Stroke Technical Info 8 11-16-2010 01:05 PM
7.3 banjo bolt kit ?'s strokefreak 1994-1997 OBS Power Stroke - Aftermarket & Performance 7 11-01-2010 11:51 PM
Leaking fuel pump banjo bolt offroad diesel 1994-1997 Power Stroke Technical Info 12 02-23-2010 03:34 AM
