2006 F250 runs rough then dies - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 01-31-2019, 01:15 AM Thread Starter
Hey guys, i'm new to diesels and need some help. My 2006 6.0 started running really rough started to bog down, and die on me. Here is the story Drove home from work late last night and noticed that at low rpm's the truck shook and ran really rough. When I made it to highway speeds (75) it seemed to correct itself, until I slowed down to a stop then it got worse. The fuel was kinda low less than 1/4 tank roughly 60 miles left on the tank. The plan was to fill up in the morning. I was able to limp the truck home and park it. I contributed the rough ride to possibly having a bad fuel gauge and was extremely low on fuel. Well this morning I went to get fuel and the truck ran rough die less than 1 mile from the house. I eventually got it to the fuel station filled it completely up, it started right up ran rough momentarily then corrected itself again. I did notice on the way home the truck ran faster than normal. Barely pressing the petal it seemed to take off down the road. I tried to take it for another ride to see if the problem was still there and it got worse. I had no power from a complete stop. The load was to much for the truck so it died again. I did some research and it seemed to be the FICM was the issue. I put voltage tester on the FICM, with the engine off there was 11.9 at the bottom screw, with the motor running there 48.6, seems to be working fine. Are there any suggestions where I should be looking into? This is my only vehicle and need to be back on the road as soon as possible. Thanks for any help I can get!
CoreySmith36 is offline
post #2 of 2 (permalink) Old 01-31-2019, 04:21 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 2006 F250 runs rough then dies
You checked things like fuel filters? One by the oil filter in the middle of the engine, one down by the t-case on driver side. They shouldn't be black lol.
Could be the ipr as well... could be a number of things...but I would start with the simple stuff.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
Similar Threads
2006 6.0 liter f250 runs rough then dies Lilpep 6.0L Power Stroke Technical Info 2 07-31-2016 03:58 PM
6.0 Runs great then dies then wait to restart then runs rough then dies... NEW2PSD6.0 6.0L Power Stroke Technical Info 9 12-11-2014 02:26 AM
Powerstroke 6.0 Starts, Runs, Then starts missing and then DIES!!! Druffing 6.0L Power Stroke Technical Info 8 05-02-2014 12:17 AM
Powerstroke 6.0 Starts, Runs, Then starts missing and then DIES!!! Druffing 6.0L Power Stroke Technical Info 0 04-29-2014 11:40 PM
99 7.3L RUNS THEN WON'T, THEN RUNS AGAIN STONE6.4L 7.3L Power Stroke Technical Info 0 04-21-2009 11:14 AM
