06 F250 bogs down and wants to die - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 01-31-2019, 01:11 AM Thread Starter
Question 06 F250 bogs down and wants to die
Hey guys, i'm new to diesels and need some help. My 2006 6.0 started running really rough started to bog down, and die on me. Here is the story Drove home from work late last night and noticed that at low rpm's the truck shook and ran really rough. When I made it to highway speeds (75) it seemed to correct itself, until I slowed down to a stop then it got worse. The fuel was kinda low less than 1/4 tank roughly 60 miles left on the tank. The plan was to fill up in the morning. I was able to limp the truck home and park it. I contributed the rough ride to possibly having a bad fuel gauge and was extremely low on fuel. Well this morning I went to get fuel and the truck ran rough die less than 1 mile from the house. I eventually got it to the fuel station filled it completely up, it started right up ran rough momentarily then corrected itself again. I did notice on the way home the truck ran faster than normal. Barely pressing the petal it seemed to take off down the road. I tried to take it for another ride to see if the problem was still there and it got worse. I had no power from a complete stop. The load was to much for the truck so it died again. I did some research and it seemed to be the FICM was the issue. I put voltage tester on the FICM, with the engine off there was 11.9 at the bottom screw, with the motor running there 48.6, seems to be working fine. Are there any suggestions where I should be looking into? This is my only vehicle and need to be back on the road as soon as possible. Thanks for any help I can get!
CoreySmith36 is offline
post #2 of 2 (permalink) Old 01-31-2019, 01:17 AM
Re: 06 F250 bogs down and wants to die
Is the truck bulletproofed? I'm no expert in the field of FICM issues, the internet has the answers you seek. Sounds like a bad injector at first but if you're sure it's the FICM then google is you best friend.
_DieselFuelOnly_ is offline
Similar Threads
Shifts and bogs down at low speed medicjodie 1994-1997 Power Stroke Technical Info 0 09-04-2015 05:50 PM
97 f250 rough idle wants to die Kcothey 1994-1997 Power Stroke Technical Info 5 04-07-2015 03:53 PM
Bogs down at full throttle and won't shift into 2nd shawnstevens 6.4L Power Stroke - Technical Info 1 03-10-2014 04:46 PM
05 - Runs rough and wants to die Bad Habit 6.0L Power Stroke Technical Info 13 01-31-2012 11:33 PM
rpm's jumping and wants to die baggedbug 1994-1997 Power Stroke Technical Info 8 03-01-2010 02:58 AM
