Looking for new rims and tires - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-23-2019, 12:44 AM Thread Starter
Gbaumann's Avatar
Hey guys, looking to replace my current setup (20x12 -44 offset 33x12.5r20). I have a leveling kit, can I fit 18x9 -12 offset fuel hostages with a 35 12.5 18 toyo at? Anyone have picks of this set up? Trying to tuck the wheel a little more into the wheel well and get a little bigger tire in there
Gbaumann is offline
post #2 of 7 (permalink) Old 01-23-2019, 12:48 AM Thread Starter
Gbaumann's Avatar
Here's a pic of current set up
File Type: jpg IMG_20181205_152440_715_1548208069352.jpg (11.9 KB, 12 views)
2005 Ford F250 Xlt Fx4
4" mbrp straight pipe
8000k hids headlights and fogs
Recon smoked cab lights
Soon: egr and oil cooler fix
Gbaumann is offline
post #3 of 7 (permalink) Old 01-23-2019, 04:42 PM
Re: Looking for new rims and tires
35x12.5x18 Ridge Grapplers on 18x9 -12 Method MR309's with 4" lift
With just a leveling kit you might (probably) get some rubbing
Sent from my SM-G960U using Tapatalk
voodooridr is offline
post #4 of 7 (permalink) Old 01-24-2019, 02:14 PM Thread Starter
Gbaumann's Avatar
That's what I was thinking but really dont want to lift it any higher. May just stick with 33s to be safe
Gbaumann is offline
post #5 of 7 (permalink) Old 01-29-2019, 07:29 PM Thread Starter
Gbaumann's Avatar
Anyone else running 35s with a 18x 9 -12 offset or a 20x10 -24 offset?
Gbaumann is offline
post #6 of 7 (permalink) Old 01-30-2019, 12:16 PM
Weatherlite's Avatar
Garage
I can't tell you that exact setup, but I'm running the metric equivalent of about a 34x11.5 on 18x9 wheels with a -12 offset on a stock suspension on an Excursion....so I'm even lower than a pickup. I had to hold back a plastic flap in the fender by about 1/2" to prevent rubbing at full lock, but that's it. Lots of clearance from any hard parts. So, I would imagine that an extra inch in height and in width, combined with a SD truck with a 4" lift, should be just fine.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #7 of 7 (permalink) Old 01-30-2019, 04:47 PM Thread Starter
Gbaumann's Avatar
Thanks man I believe I have a 3 in labeling kit with 1 in rear block. I'm not afraid to cut the line but dont want to cut the fender or bumper. I'm still debating on 33s or 35s at this point but I feel 35s would fill up the wheel well nicely
Gbaumann is offline
