CCV mod idea ( keeps it intact ) - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By sooty
post #1 of 8 (permalink) Old 12-27-2018, 04:09 AM Thread Starter
BKB
I would like to reduce or eliminate the oil consumption threw the factory CCV but keep it a sealed system. Has anyone tried cutting the vacuum pipe inside the intake tube flush? I would think this would reduce the vacuum on the crank case and should reduce the amount of vapor pulled into the intake. I have had a few diesels and always vented them to atmosphere, I never had a drop of oil come out of any of vent hoses. I cant stand the smell of the new oils and want to try and retain the closed loop, I have a muffler so I cant run it into the exhaust. Am I way off thought here?
BKB is offline
post #2 of 8 (permalink) Old 12-27-2018, 11:52 AM
Moderator
Sbluke55's Avatar
Re: CCV mod idea ( keeps it intact )
https://www.google.com/amp/s/shop.fu...2170%3Famp%3D1
Just buy a ccv filter.
01 f-250, Standard
Sbluke55 is offline
post #3 of 8 (permalink) Old 12-27-2018, 11:58 AM
Moderator
Sbluke55's Avatar
@Zmann uses a different one. He will stop by and tell you.
01 f-250, Standard
Sbluke55 is offline
post #4 of 8 (permalink) Old 12-27-2018, 11:12 PM
Administrator
Zmann's Avatar
you can tie in after the muffler
i run a racor 6000 and back to the stock location
it separates the oil and keeps the intake clean
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 8 (permalink) Old 12-29-2018, 01:07 PM
sooty
Don't cut it off flush, that will have the same affect as pinching the hose off completely with vise grips.
Why can't you plumb it into the exhaust before the muffler? I have don't it that way since 2010 on multiple diesels and never had an issue. On trucks with catalytic converters I go just downstream of them with a proper venturi fitting
Zmann likes this.
sooty is offline
post #6 of 8 (permalink) Old 12-29-2018, 01:13 PM
Administrator
Zmann's Avatar
i agree I was picturing CAT honeycomb innards for the muffler
the muffler can deal with oil
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 8 (permalink) Old 12-29-2018, 02:04 PM Thread Starter
BKB
I was way off base with this idea, thought the chimney was facing backwards creating a vacuum. Just looked and see its facing the incoming air stream. I have never tested but figured exhaust back pressure would be too high before a muffler. Might make my own CCV filter.
BKB is offline
post #8 of 8 (permalink) Old 12-29-2018, 03:14 PM
Administrator
Zmann's Avatar
DTR's Donation page
RIP DTR Ron
Zmann is offline
