2 stroke oil in a 6 liter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-22-2010, 03:19 PM Thread Starter
Mpoage's Avatar
I've been reading about people running 2 stroke oil in there fuel to help keep the injectors running smoothly and to keep them quiet. I've been running the lucas injector cleaner and what not but I can't see any real difference. What kind of oil do you use and what ratio do you put to a gallon of diesel. Also what is the best synthetic oil to use for it to. Thanks in advance.
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #2 of 10 (permalink) Old 03-22-2010, 03:59 PM
Guest
Posts: n/a
Re: 2 stroke oil in a 6 liter
I go by the book. I use Motorcraft 15-40 from April to October and Motorcraft HD 10-30 through the winter. I have been useing Powerservice year round but I just bought three gallons of the Motorcraft perfomance/cetane boost and it works better. It was $33.00 a gallon and it treats 500 gallons. I bought it online. If you decide to use it I can post the link. I never used 2 stroke oil. I have tried syn oil and I really didn't any benifit from it and it was double the price. I change my oil every 3 to 4K.. Truck runs great..
post #3 of 10 (permalink) Old 03-23-2010, 12:21 AM
Power Junky
Lubbockguy1979's Avatar
32oz to the gallon. tcw3. i use wally world supertech. it is 11.89 i think with tax here. treats 4 tanks. make the truck noticibly quieter at idle. i havent noticed any significant mpg improvement. i did run the diesel kleen and didnt notice any gains or noise reduction what so ever. fuel filters with diesel kleen, straight diesel and two stroke oil were all clean at 15k intervals. the only difference was with the two stroke there was a little blue hue to the filters once i tore past the water seperator
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #4 of 10 (permalink) Old 03-23-2010, 12:26 AM
King Dingaling
TANK'S 250's Avatar
Been using Wally World 2 cycle for years in my 2005 6.0l....never had an issue,..quiets the engine,..and lubes everything nicely..
1oz per gal of diesel
TANK'S 250 is offline
post #5 of 10 (permalink) Old 03-23-2010, 01:08 AM
to the last 2 posters. Wally world is very popular because it is cheap and meets the requirements. Other's will work as well, just make sure it meets the requirements and is ashless.
2004 F-250 Lariat X-Cab LB
  • Arp Head Studs w/Black Onyx Gaskets
  • MBRP 4" Turbo Back
  • SCT with tunes from ID and Gearhead
  • Oil and Coolant Bypass Filters
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight Monitors EOT, ECT, Tranny Temp
  • Anti Hi-Jack Device by Glock 9mm!
  • And tons more modded
pro350hydro is offline
post #6 of 10 (permalink) Old 03-23-2010, 02:08 AM Thread Starter
Mpoage's Avatar
Thanks for all the help. gonna go fill up later and see what it will do.
Straight Piped
Edge Insight
Mpoage is offline
post #7 of 10 (permalink) Old 03-23-2010, 03:51 AM
Power Junky
that and any town with 4 people and 5 dogs has a walmart around here. they are more common that autozones
Randy
post #8 of 10 (permalink) Old 03-23-2010, 05:23 AM
hypersnyper694788's Avatar
I use Motorcraft fuel additive. Is it ok to use that and the 2 stroke oil at the same time, or should i use one or the other? If so which one?
06' F-250 CC SRW 4x4, 6" fabtech lift, bilstien 5100 shocks, 4" MBRP TB no cat, ARP studs, 2 JL audio 10" W0, 20x12 weld cheyenne 8's, 35x13.50x20 Mickey Thompson Baja ATZ
BNIB 6.0 head with all related hardware, straight from FORD. For Sale PM me offers
hypersnyper694788 is offline
post #9 of 10 (permalink) Old 03-24-2010, 12:35 AM
Will motorcyle 2 stroke oil work? It is not TCW3, however it is ashless. I work at a Yamaha dealership and I get Yamahlube 2R (Yamaha's Best) fairly cheap. What do you guys think?
Bhodge
bhodge is offline
post #10 of 10 (permalink) Old 03-24-2010, 01:07 AM
It's fine. I have run 2-stroke oil with other additives at the same time.
