6.0 s366 boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-23-2018, 09:06 PM Thread Starter
6.0 s366 boost
I just recently installed a non vgt turbo on my 07 powerstroke the specs are 66/74/91 I got all stock fuel system with innovative xtreme x tune mods are 5" no limit intake 3.5" down pipe I was curious if 20psi of boost was normal with tow/haul on thanks
Rpbobby492 is offline
post #2 of 4 (permalink) Old 12-23-2018, 11:41 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 6.0 s366 boost
That turbo is meant to be used with larger than factory injectors, ideally. That, and considering you don't have things like a 4" downpipe, I suppose 20psi is to be expected. It needs custom tuning too, not just generic "cookie cutter" tunes.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 4 (permalink) Old 12-24-2018, 12:05 AM Thread Starter
Ok thank you but it does have a tune from innovative diesel for a s366 non vgt I've just seen videos of other 6.0 getting 30 psi just wasn't sure
post #4 of 4 (permalink) Old 01-08-2019, 08:28 PM
Re: 6.0 s366 boost
You definitely need a little bit more on the fuel side to take advantage of that turbo. Im sure it is quite laggy as well. 175/80s or something in that ball park is what Id pair with a charger like that. What else is done to your truck?
I just went to a non VGT setup in my truck and went with a 62/68/.83 SXE w/ Irates T4 Kit. I am on stock injectors. Gearhead wrote my files and I absolutely love the set up, came from a Powermax. Not sure what I am making for boost but around 1/2-3/4 throttle I max out my Edge Insight that reads through the OBD2 @ 29lbs. I assume Im seeing somewhere between 35-40 at WOT, gonna install an actual boost gauge at some point here.
Darianmacdonald is offline
