Boost gauge? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-19-2010, 07:10 PM Thread Starter
Mean Green
kh_strokin07's Avatar
Boost gauge?
Where is the best place to drill/tap into for ur boost hose? pictures would be awesome. if not thats ok
2006 f-250 Harley davidson, stock everything
kh_strokin07 is offline
post #2 of 7 (permalink) Old 03-19-2010, 07:18 PM
FFRyan's Avatar
Re: Boost gauge?
Intake elbow on the top of your engine, it has a black hard platic tube running into it.
FFRyan is offline
post #3 of 7 (permalink) Old 03-19-2010, 08:07 PM
Proud Sponsor
Abrannan19's Avatar
Re: Boost gauge?
actually his is an 04, it should have a metal tube running into it.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #4 of 7 (permalink) Old 03-19-2010, 08:11 PM
Power Junky
Lubbockguy1979's Avatar
Re: Boost gauge?
Go to diesel manor they have a tech file that has pictures. Mark the intake elbow with a sharpie on the truck in a place that will not interfere with anything. Pull the 4 bolts and be easy they will break if your rough with them. Pull the intake off. Drill the intake it is aluminum so it is fairly easy to drill be easy with the tap it is aluminum and stripping threads is easy. Install the fitting into the intake elbow use teflon tape to make a tight seal. Remember not to over torque it. Then install the elbow after you clean it up. Use a back up when hooking up the boost line.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #5 of 7 (permalink) Old 03-22-2010, 10:43 PM Thread Starter
Mean Green
Re: Boost gauge?
the intake elbow that comes off so you can get to the egr valve?
post #6 of 7 (permalink) Old 03-22-2010, 10:50 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Re: Boost gauge?
Yes the silver colored elbow with the little stud going to the plastic shroud Right in front of the EGR valve. 3-Gauge Install Pictures Theres a image!!!!
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #7 of 7 (permalink) Old 03-22-2010, 10:55 PM Thread Starter
Mean Green
Re: Boost gauge?
Right on man thanx!!!!
