DD clutch ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-16-2010, 03:34 PM Thread Starter
STROKER6.04LIFE's Avatar
DD clutch ???
Ok I need a dd clutch I just got injectors, turbo and I'm hopping close to 550-600 rwh. Does somebody uther then south bend make a dd for a 6.0 they are 1700 that is a bit pricy if not can sombody get a beter deal thanks
STROKER6.04LIFE is offline
post #2 of 6 (permalink) Old 03-16-2010, 04:02 PM
Re: DD clutch ???
check into valair
halerazor is offline
post #3 of 6 (permalink) Old 03-16-2010, 06:07 PM Thread Starter
Re: DD clutch ???
Ok thanks
post #4 of 6 (permalink) Old 03-17-2010, 07:28 AM
Re: DD clutch ???
just remember, you get what you pay for. Go South Bend!
2008 F350 Lariat 6speed!
85yota350 is offline
post #5 of 6 (permalink) Old 03-17-2010, 02:40 PM
Re: DD clutch ???
valair and south bend use the same parts for their clutches theres a thread om comp about it. If money isn't an object call Haisley machine the make the best pulling clutches bar none!! I had about $3500 in mine that was including flywheel and input shaft.
post #6 of 6 (permalink) Old 03-17-2010, 02:48 PM Thread Starter
Re: DD clutch ???
No that's not it at all cash is a problem. I've spent to much on my truck in the last 2 months about 5 grand and I'm doing all the work so save 300 for the same clutch and the same 12 mo/12 mile war I calls yeserday and talked to them
