Best option for injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-15-2018, 07:44 PM Thread Starter
Hello, I have a 2006 f250 with 265,000 miles. I just had an injector go out on me. I understand with the 6.0 it’s best to buy OEM injectors. Is there an option that is slightly better than factory but not much more expensive? I’m looking for a drop in and go injector without a tune needed. Thanks in advance, Brandon.
2006 6.0 260,000
6.NO is offline
post #2 of 7 (permalink) Old 05-15-2018, 07:45 PM Thread Starter
Truck is stock with exception of ficm tune, turbo back exhaust, and coolant filter.
2006 6.0 260,000
6.NO is offline
post #3 of 7 (permalink) Old 05-15-2018, 07:51 PM
79jasper's Avatar
Re: Best option for injectors
You won't really get any benefits of a bigger injector, without tuning.
79jasper is offline
post #4 of 7 (permalink) Old 05-15-2018, 11:14 PM Thread Starter
Alright thanks for the info. What about irdering stock injectors? Where is the best place? I have heard a lot about remans being bad. Anyone have good info on this?
2006 6.0 260,000
6.NO is offline
post #5 of 7 (permalink) Old 05-15-2018, 11:46 PM
79jasper's Avatar
Reman from a parts store might be junk.
Even if just doing stock rebuilds, I would get them from one of the well known diesel companies.
You should be able to find some names in the site sponsor/vendor section.
79jasper is offline
post #6 of 7 (permalink) Old 05-19-2018, 02:51 PM
Phil G's Avatar
I ordered a set of 8 OEM's from Rock Auto a couple months ago. Returning the cores will cost a few bucks but the process to return them is step by step laid out on your order. It was no big deal. They were under $200/piece.
Current Truck-07 F350 6.0L Diesel 4x4 172"WB
Past - 99.5 F250 172", 2003 F350 7.3 172", 2004 172"
Phil G is offline
post #7 of 7 (permalink) Old 05-19-2018, 04:13 PM
79jasper's Avatar
After more research, if going stock size, just get actual OEMs from ford. They do have a better warranty as well.
79jasper is offline
