Whats the diff between a 6.0 trans and 6.4? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-15-2010, 12:37 AM Thread Starter
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Like the title says...I know there the same but i heard they a beefier...Say i got one what would i have to do to swap just use my converter?
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #2 of 18 (permalink) Old 03-15-2010, 01:15 AM
Proud Sponsor
Abrannan19's Avatar
Re: Whats the diff between a 6.0 trans and 6.4?
the 6.0 converter is a 6 bolt style and the 6.4 converter is a 8 bolt style, there are some internal difference between the two also, the filter is different I believe and the trans pan on the 6.4 is slightly different too.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 18 (permalink) Old 03-15-2010, 01:17 AM
Brentos's Avatar
there is also a planetary that is unservicable in the 6.4 also.. but the only difference that will make them un changable is the TC
Brentos is offline
post #4 of 18 (permalink) Old 03-15-2010, 01:34 AM Thread Starter
<-MONEY PITT!!
So u cant just switch converters? a 6.4 trans wont work at all?
post #5 of 18 (permalink) Old 03-15-2010, 01:41 AM
Proud Sponsor
Abrannan19's Avatar
someone said you can use the 6.0 flywheel and the 6.4 transmission will work with no problems..I don't know about that though... I have been looking at diagrams
Adam Brannan
Email
post #6 of 18 (permalink) Old 03-15-2010, 02:40 AM
Brentos's Avatar
Yes you can..just swap converters
Brentos is offline
post #7 of 18 (permalink) Old 03-15-2010, 02:49 AM Thread Starter
<-MONEY PITT!!
Sweet deal man Thanks for the info!!
post #8 of 18 (permalink) Old 03-16-2010, 03:02 PM
FFRyan's Avatar
the pan is also deeper and has a better filter, they will also fit the 6.0 trans. My 07 has the 6.4 trans pan and filter.
FFRyan is offline
post #9 of 18 (permalink) Old 03-17-2010, 04:06 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Actually just ran into this scenario. Converter was speced by the customer and was brought in while we were building the torqshift from his 6.4L. The billet cover was drilled and tapped for 6 and 8 bolts. Something was up with the converter when it was welded together. The offset for the converter clutch was slightly different. It went into lockup, 1 time. And then never again. Put the stock one back in and it was perfect.
If it had used the 6.0L flexplate it would probably have worked. It only takes being off by .010 to .020s to not work.
This is why we like to do stuff in house and not mess with outside headaches.
Intermediate clutch stack up is a little different in the 6.4L if I remember correctly. Have to check the notes from the CNC program that cuts the pistons.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #10 of 18 (permalink) Old 03-17-2010, 04:09 AM
Proud Sponsor
Abrannan19's Avatar
Good info Doug.
Adam Brannan
Email
