Head Gaskets Again? Need Advice - Page 8 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #71 of 73 (permalink) Old 03-20-2010, 06:39 PM
Specializeddieselnw's Avatar
Re: Head Gaskets Again? Need Advice
So........back to the thread topic......You say it's a whistling coming from the degas bottle? Usually if the cooling system is being pressurized by combustion from head gaskets leaking, You will puke coolant out of the bottle.
If it's just a whistling noise, especially at 50 psi of boost, I'd check for a turbo hose leaking somewhere. All it takes is a pin hole or a slightly loose clamp at those pressures to be noticeable
Specializeddieselnw is offline
post #72 of 73 (permalink) Old 03-20-2010, 06:41 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Originally Posted by lubeowner View Post
The 6.0 crank doesn't have enough throw in it to get the piston deck height right. But the 6.4 crank have enough extra material that we should be able to work. Closer to 7.6.
Probably be easier to send the crank to Marine Crank or Winberg to have them weld it. Then it could be reground, induction hardened, and micro polished.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #73 of 73 (permalink) Old 03-20-2010, 06:42 PM
Captain Negativity!
PSDPlayer's Avatar
The cab is already off of the truck...
Email:
