New to the 6.0 Basic Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-02-2018, 10:42 PM Thread Starter
I may be trading my 97 7.3 for a 2005 6.0 ZF6. With that said, while I know a decent amount about the 7.3, I know nothing about the 6.0. The guy says the motor runs fine and it has a new trans and clutch with paperwork, as well as 4 new injectors. He deleted the egr, put new headstuds and head gaskets in and he replaced the water pump. I know there is a huge list of parts that can be associated with bulletproofing the 6.0. If I just wanted to keep the power level stock or maybe even run a mild tune, what other parts would be necessities to upgrade to make the engine "more-bullet-proof"?
Melamed555 is offline
post #2 of 3 (permalink) Old 04-03-2018, 01:49 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: New to the 6.0 Basic Questions
sct fitting on the hpop, new ford oil cooler (really you should get something like a Bulletproof Diesel oil cooler reroute, which gets rid of the coolant-to oil cooler in the valley and sends the oil to a radiator up front.), if you stick with the stock oil cooler, get a coolant filter kit. If it has the NAPA oil filter cap on it (which is distinctly much taller than the ford factory cap) don't buy it. Likely has let a bunch of crud past the filter into the oil system. Lots of problems later on.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 3 (permalink) Old 04-03-2018, 07:01 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
did he mention that he did the standpipes or dummy plugs? or a 'blue spring' upgrade (fuel pressure regulator spring upgrade)?
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
