Adjusting shift firmness on custom tune with SCT X4? Bad idea? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By IQRaceworks
post #1 of 8 (permalink) Old 03-30-2018, 05:15 PM Thread Starter
IQRaceworks's Avatar
Question Adjusting shift firmness on custom tune with SCT X4? Bad idea?
I've been running IDP custom tunes on my SCT X4 for a while, and they work great. I have the Extreme Street (140hp +/-) , Street (100hp +/-) , and Towing tunes (60hp +/-). I mostly just run the towing tune.
When ever I change a tune using the SCT X4, I have the option of changing the shift points, and also the shift firmness in each gear. If I'm running a "custom tune", not one of the SCT canned tunes, is it ok to mess around with the shift points and firmness.......or should I just leave all of that alone? I know I can have IDP adjust stuff for me......I was just curious if I can do it myself using the SCT X4 since it gives me that option.
Thanks!
IQRaceworks is offline
post #2 of 8 (permalink) Old 03-31-2018, 01:49 PM
Master BS'er
jamiesaun's Avatar
Re: Adjusting shift firmness on custom tune with SCT X4? Bad idea?
Well, if it's shifting too early or too late, then sure, why not. If it's shifting way too hard or taking forever then same thing. Go for it.
If the timing and firmness seems normal, then don't mess with it. The tcm is supposed to be adapting all of that on it's own. But I don't know what happens when different software is thrown into the mix.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 8 (permalink) Old 03-31-2018, 04:29 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The TCM does not adapt when it shifts. It only adapts how hard it shifts.
Mark
Mark Kovalsky is online now
post #4 of 8 (permalink) Old 03-31-2018, 05:15 PM
Master BS'er
jamiesaun's Avatar
I see.
Brother James
post #5 of 8 (permalink) Old 04-02-2018, 11:51 AM Thread Starter
I talked to one of the guys at IDP....he pretty much told me not to mess with it. No real technical answer.....just "leave it alone". So at this point....I guess that's what I will do.
jamiesaun likes this.
post #6 of 8 (permalink) Old 04-02-2018, 12:02 PM
Master BS'er
jamiesaun's Avatar
That's probably pretty good advice. Especially if there are no complaints with how it's shifting.
Brother James
post #7 of 8 (permalink) Old 04-02-2018, 12:04 PM
Master BS'er
jamiesaun's Avatar
I cleared the adaptive values on a tcm one time, I can't remember why I did that now. But when I took it for a test drive it felt like the trans was going to fall out of the truck it was so bad. Took a while for it to go back to normal too.
Brother James
post #8 of 8 (permalink) Old 04-02-2018, 12:24 PM
79jasper's Avatar
I would have to assume idp already has your trans tuning. So yeah, don't touch it.
And yes, there's procedures for resetting the adaptive.
79jasper is offline
