need some mod help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-11-2010, 01:16 PM Thread Starter
bpb424's Avatar
Talking need some mod help
I have decided to cross to the dark side and mod my 6.0. As of right now I have a 4" turbo back exhaust (cat delete) and an SCT with custom tunes.
My first priory is head studs and an EGR delete. Should I next do injectors and a fuel system? or a turbo upgrade first? I know I want a non-VGT (i hate that stupid whistle, sounds like a vacuum cleaner).
As for sticks I want something around 175-190ml. What fuel mods will I need to support this? I want an airdog 2, but I don't know what else I need fuel system wise.
Thanks for the help guys. This will be a DD that tows a car trailer every once in a while
2008 F250 King Ranch
6" lift on 37's
KEM 275, 345 on DD
EGR delete, no limit pipe
AFE intake
bpb424 is offline
post #2 of 14 (permalink) Old 03-11-2010, 02:02 PM
STROKER6.04LIFE's Avatar
Re: need some mod help
I'm doing the same rite now I have 190s and I'm running a AirDog150. U will need a pump what brand that's for u to pick some people like AirDod some like FASS and uthers like uther brands. Like I was told u can run the stock turbo with 190s. So I would do injectors and suporting mods u can always do a turbo in the future. Also remember u should do a oil cooler rebuild y u are in that far. U should also look into a oil and coolent filtration system all good suporting mods and will make a big dif in the long hall good luck with the build hope I helped some
STROKER6.04LIFE is offline
post #3 of 14 (permalink) Old 03-11-2010, 02:13 PM
Stroker67's Avatar
you cant run a stock turbo with 190s, if your going to Tow alot i recommend 155 sticks, you can run those with a stock turbo. When i do my fuel system upgrade i plan on using airdog 2. headstuds and an EGR delete are a good thing to do. If your wanting 190s youll probably run hot depending on how heavy you tow. CAI wouldnt be a bad thing either.
Stroker67 is offline
post #4 of 14 (permalink) Old 03-11-2010, 02:23 PM
Sorry I didn't see the last small pragraph ya def 155s for towing my bad
post #5 of 14 (permalink) Old 03-11-2010, 03:38 PM Thread Starter
bpb424's Avatar
towing would only be 3-4 times a yr.
with an airdog2 do I still need a reg return or anything else to support the injectors?
6" lift on 37's
KEM 275, 345 on DD
AFE intake
bpb424 is offline
post #6 of 14 (permalink) Old 03-11-2010, 06:10 PM
motoxracer42's Avatar
you can run 190s with a stock turbo. it wont hurt anything your tuner just has to know what he or she is doing. i ran my stock turbo with 205s for towing. that got a little warm but i towed a heavy trailer. what kind of towing are you doing? how heavy
06 crew cab
06 reg cab
motoxracer42 is offline
post #7 of 14 (permalink) Old 03-11-2010, 06:12 PM
lol nevermind i just saw it. whos 190s are you getting? that will make a difference also.
06 crew cab
06 reg cab
post #8 of 14 (permalink) Old 03-11-2010, 06:49 PM Thread Starter
bpb424's Avatar
I have been looking at RCD's 175's. I don't know if 190's would be too big of a jump or not. What fuel supporting fuel system mods would be needed?
6" lift on 37's
KEM 275, 345 on DD
AFE intake
bpb424 is offline
post #9 of 14 (permalink) Old 03-11-2010, 09:35 PM
i would talk to whoever you order the injectors from. you will at least need a lift pump.
06 crew cab
06 reg cab
post #10 of 14 (permalink) Old 03-11-2010, 10:17 PM
Power Junky
Lubbockguy1979's Avatar
Anything over 155 is a definate for some sort of fuel upgrade. With 155's I'd at least do a cross over and drill the banjo bolts or get upgraded ones.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
