Tranny problem with Deranged, Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-11-2010, 02:29 AM Thread Starter
Sponsor
dalpilot's Avatar
I have a few folks, including Doug, working on this. When I put the tranny in R, it goes to reverse, when I go to N it goes to N, when I put it in d,3,2,or 1, it goes into a very high gear, and does not shift, at all. It will drive, but the Tranny temps go through the roof, and it stays in whatever gear its in. I checked, its got power from the TCM, to the transmission, the ground at the tranny is good, but no shifting. What am I missing? Its a brand new 5r110 from TCI. It sat around for almost 2 years before being installed. Any suggestions????
dalpilot is offline
post #2 of 9 (permalink) Old 03-11-2010, 03:29 AM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Tranny problem with Deranged, Help
i put a trans in out of a salvage yard bout 6 months ago and mine was doing similar.... i ended up playin with the linkage on the adjustment right on the shifter arm on the trans and it finally started workin properly.... may not be the fix but its a shot... can't wait to see it run!
Fordfreak4life is offline
post #3 of 9 (permalink) Old 03-11-2010, 03:32 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
You need to get access to data pids that you dont have before putting out an internet SOS... The most simplest of questions need to be answered by 1 pid. What is the commanded gear? And when you put it in the manual gears, why don't they manually apply? Did TCI leave the manual valve disconnected in the valve body? If you disconnect the TCI shifter from it and feel each detent if the manual valve was sticking you will have some great effort trying to move it.
The enhanced OE interface on autoenginuity's website shows TCM CAN access.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 9 (permalink) Old 03-11-2010, 11:56 AM
GOOSEKILLER's Avatar
Hope you get it figured out can't wait to see that thing run.
2001 2500 4x4
Built 12 valve
TNT Performance
GOOSEKILLER is offline
post #5 of 9 (permalink) Old 03-12-2010, 03:15 AM
<-- Got Air ?
Craig@MPD's Avatar
ive seen this in a few trucks when two seliniods firing at the same time
does it go into gear real hard?
post #6 of 9 (permalink) Old 03-12-2010, 03:47 AM Thread Starter
Sponsor
dalpilot's Avatar
Yes.
dalpilot is offline
post #7 of 9 (permalink) Old 03-12-2010, 05:00 AM
<-- Got Air ?
Craig@MPD's Avatar
yes you have a vlvebody problem i believe
I would pull the valvebody and test or replace the seliniods and take the valvebody apart theres a screen/gasket inbetween to to section of the valvebody and make sure its the oring part of it is in good condition and didnt get messed up
sounds like your 3-5 seliniod is stuck on
post #8 of 9 (permalink) Old 03-12-2010, 01:29 PM Thread Starter
Sponsor
dalpilot's Avatar
Thanks Craig. I have some help with diagnosing it too. I appreciate it.
dalpilot is offline
post #9 of 9 (permalink) Old 03-17-2010, 12:40 AM
Captain Negativity!
PSDPlayer's Avatar
The TCM receives critical information from the ECM via CAN. If the CAN link fails, the TCM no longer has torque or engine speed information available – the high side switch will be opened. The TCM will store a U0100 fault code if unable to communicate with the TCM.
Email:
