injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-10-2010, 03:54 PM Thread Starter
2003f250's Avatar
injectors
im thinking about getting a set of 190cc injectors will i need studs before i do that or will the injectors pretty much blow the head gaskets if i dont have studs already?
2003f250 is offline
post #2 of 4 (permalink) Old 03-10-2010, 04:48 PM
SamW's Avatar
Re: injectors
is your truck stock now? your going to want studs and an egr delete to run bigger injectors along with a fuel pump upgrade, custom tunes and a few other things first.
2006 F250 CCSB
6.
SamW is offline
post #3 of 4 (permalink) Old 03-10-2010, 05:18 PM
aggie's Avatar
Re: injectors
You could run the 190s without studs but you would want to run a fairly stockish file with some transmission shifting built in to it. once you have the studs you could run hotter files.
[SIGPIC][/SIGPIC]
aggie is offline
post #4 of 4 (permalink) Old 03-11-2010, 12:18 AM
SamW's Avatar
Re: injectors
but wouldnt you just be better running a custom tuned sct with stock injectors turned all the way up? just seems like a matter of time...
2006 F250 CCSB
6.
SamW is offline
