looking at 6.0 powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-10-2010, 07:02 AM Thread Starter
i am looking at an 2006 powerstroke but i keep reading about these head gasket failures some guys say it was just in the early years but i read that they are in every year what is the deal i dont wanna spend 20 grand on a used truck and blow head gaskets thanks for the help
rednexinc15 is offline
post #2 of 13 (permalink) Old 03-10-2010, 12:09 PM
Brentos's Avatar
Re: looking at 6.0 powerstroke
spend twenty grand on what? if your putting that into performance parts then three grand of it goes towards new gaskets and arp studs and you will be fine
Brentos is offline
post #3 of 13 (permalink) Old 03-10-2010, 02:20 PM
Hate 'R Us
!!!PainTrain!!!'s Avatar
Pretty sure he's talking about buying a $20,000 truck, not just that much in performance parts.
OP: Do yourself a favor, if you buy the truck the first things you should do should be this:
1. ARP studs (make sure the heads are FLAT and the block isn't cracked/warped)
2. EGR Delete, completely get rid of it. It causes nothing but problems.
3. Run synthetic oil like 5w40 valvoline, might be wise to invest in a oil filtration system as well.
!!!PainTrain!!! is offline
post #4 of 13 (permalink) Old 03-10-2010, 02:33 PM
jroller's Avatar
Your gonna want a good coolant filtration system too. Oh and keep a bicycle in the bed.
2001 PSD DP Tuner, John Wood VB, International Up Pipes, 4" TBE, BHAF.
1994 CTD BHAF, no plate, 3GSK, Star wheel cranked, BD VB, Luke's Link, 4" exhaust, SDX 5x14 injectors,BD Super B (s300) turbo.
I like all Diesel trucks
jroller is offline
post #5 of 13 (permalink) Old 03-10-2010, 07:58 PM
PETE ENGR PSD
You will also want to run an OASIS report on the truck if not done yet.
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #6 of 13 (permalink) Old 03-10-2010, 09:13 PM
Guest
Posts: n/a
Not all 6.0's blow headgaskets. I know a bunch of guys that own them and have only known one that had gasket problems. He added a bunch of power to it and drives it like an idiot.. I have had two 6.0's and no gasket problems and both where chipped. I tow heavy regularly and use the diesel for it's intended purpose..
post #7 of 13 (permalink) Old 03-10-2010, 09:45 PM
Stroker67's Avatar
as stated above, first and foremost get an Oasis that way you can see if the truck has had any issues that were fixed under warranty or by a dealership. As pain train said, Headstuds(either ARP or H-11), Delete the EGR system completely(I have FCDP's kit and love it), and a Synthetic oil will help out greatly. Also a coolant filter will help with clogged oil coolers.
Stroker67 is offline
post #8 of 13 (permalink) Old 03-10-2010, 10:10 PM
mitchell
ONESICK6.0's Avatar
My truck is an 03.5 with 102000 miles on it last time i had it on a dyno i was around 450hp. And so far (knock on wood) My head gaskets are fine EGR delete with some black onyx head gaskets with ARP studs you will be just fine.
ONESICK6.0 is offline
post #9 of 13 (permalink) Old 03-11-2010, 06:15 AM Thread Starter
where do i get this oasis report can the dealer get it or do i got to
post #10 of 13 (permalink) Old 03-11-2010, 01:19 PM
Hate 'R Us
Give them the VIN and ask them for an oasis.
