Injector Install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 03-09-2010, 07:59 PM Thread Starter
rrr
rrr's Avatar
Injector Install
Im about to put larger injectors in my truck. Does anyone have any pictures/important tips I should know?
Also where I can I find the torque specs for injector hold downs etc.
rrr is offline
post #2 of 25 (permalink) Old 03-09-2010, 08:15 PM
Brentos's Avatar
Re: Injector Install
make sure injector cups and the injector hold down bolt hole are clean of oil and debre and torque the injector to 37 NM with a GOOD torque wrench..no crap or you will have issues....
when taking off the oil logs (t30) also remove the rear standtubes before removing the oil log itself and make sure to put grease on all orings before reinstallation
Brentos is offline
post #3 of 25 (permalink) Old 03-09-2010, 08:29 PM Thread Starter
rrr
rrr's Avatar
Thank you
rrr is offline
post #4 of 25 (permalink) Old 03-09-2010, 08:43 PM
motoxracer42's Avatar
also make sure you have a long t40 to get to the injector hold down without damaging the injector.
06 crew cab
06 reg cab
motoxracer42 is offline
post #5 of 25 (permalink) Old 03-09-2010, 09:19 PM Thread Starter
rrr
rrr's Avatar
A long t40 or a t40 on a long extention?
rrr is offline
post #6 of 25 (permalink) Old 03-09-2010, 09:29 PM
Brentos's Avatar
Long t40
Brentos is offline
post #7 of 25 (permalink) Old 03-09-2010, 09:37 PM Thread Starter
rrr
rrr's Avatar
rrr is offline
post #8 of 25 (permalink) Old 03-09-2010, 10:54 PM
like this some of the later models use a t45 but it should be a t40.
06 crew cab
06 reg cab
post #9 of 25 (permalink) Old 03-09-2010, 11:51 PM Thread Starter
rrr
rrr's Avatar
Yes, thank you. I appreciate it.
rrr is offline
post #10 of 25 (permalink) Old 03-10-2010, 03:16 AM
Gettin ready to do mine this weekend. This will help. I couldn't remember what size the inj hold downs were. Thanks
2003 F250 CC SB FX4
6.0 Powerstroke
BLOWN HEAD GASKETS
RCD 190 CC Injectors
SCT XCal w/ RCD Tuning
EGR DELETE
Autometer GS Series: EGT, Fuel PSI, Trans, Boost
Air Dig II
Bully Dog RFI
Silverline 4 In Turbo Back - No Muffler
No Kitty - Zoodad - High Idle
315/75R16 Cooper Discoverer STT
Pure Diesel Power 8 In Tip
03F2506.0 is offline
