Stock or Aftermarket Headgaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-09-2010, 04:53 PM Thread Starter
which ones? the "Black Onyx" ones or the stock ones??? I am using ARP head studs..... replacing the oil cooler and installing a coolant filter as well.... oh and with the oil cooler, is there an aftermarket one or should i just buy a new one from ford? any suggestions are greatly appreciated......
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #2 of 7 (permalink) Old 03-09-2010, 05:12 PM
PETE ENGR PSD
Re: Stock or Aftermarket Headgaskets?
You can just do an oil cooler rebuild from Ford.
I use the black onyx ones, as far as durability someone else might be able to chime in. But IIRC they are cheaper and as good, if not more durable than the stock ones.
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #3 of 7 (permalink) Old 03-09-2010, 05:23 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
When i studded my truck elite said stockers are fine...If you aremaking 50 plus psi of boost they said aftermarkets...and even special studs like elite makes...But i have had no issues with my stockers with studs and i spray the #### out of the poor girl...I know i had to buy head bolts with my gaskets from ford they wouldnt just sell the gaskets it was like a kit kinda lame!! So i was left with new junk ass ford bolts!!
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #4 of 7 (permalink) Old 03-09-2010, 05:33 PM Thread Starter
well there are kits from ford on ebay with all the gaskets needed to include head bolts... i will be using arps...... i was just wondering if the stock ones that come in that kit would work for me..... its modded but not extremely
post #5 of 7 (permalink) Old 03-09-2010, 05:37 PM
40 lug nuts
Snake's Avatar
Yes, stock gaskets will work fine. A lot of folks go with the Black Onyx gaskets because they're less expensive and work equally well. There's a number of vendors on this site that sell the Black Onyx gaskets and I'm guessing you'd pay less for them than buying gaskets and bolts off eBay.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #6 of 7 (permalink) Old 03-09-2010, 06:04 PM Thread Starter
I do buy from the vendors on here.....just ask ABrannan.... and will continue to, I like the black onyx ones, but i also need all the gaskets to complete the job, does any of the vendors sell the whole kit with black onyx gaskets and a set of arps? if soo shoot me a price please and thanks......
post #7 of 7 (permalink) Old 03-09-2010, 06:08 PM
Power Junky
Lubbockguy1979's Avatar
David (Powerstroke racer) is a vendor and will give you a good price. Bought mine from him. I got the victor reinz gaskets they are black mls and a lot cheaper than the black onyx gaskets... Look exactly the same about half the cost. I got my intake gaskets off ebay $30.06 on a auction and the oil cooler was $183. Saved over $100 bucks on the oil cooler and intake gaskets. If you need part#s or info on the gaskets pm me and ill get you the info. I'm welding the egr cooler and checking the heads and after that I anticipate a solid dependable truck. Not that it hasn't been already.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
