About to turn it up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-05-2010, 11:47 PM Thread Starter
About to turn it up
I have a 2004 van with the 6.0 and just realized Bullydog makes a programmer for it. I'm fabbing a 4" exhaust to bolt on at the same time. My question is, with all the problems the 6.0 has, what should I do to ensure I don't blow my motor? I've got just over 150,000 miles on it and had the FICM replaced a few hundred miles ago.
joemugg is offline
post #2 of 11 (permalink) Old 03-05-2010, 11:49 PM
Re: About to turn it up
leave that bullydog at the store
firef1523 is offline
post #3 of 11 (permalink) Old 03-06-2010, 12:30 AM
SamW's Avatar
Headstuds, egr delete, custom tuned sct. If you really want the sound get an intake and straight pipe it. Leave it at that.
2006 F250 CCSB
6.
SamW is offline
post #4 of 11 (permalink) Old 03-06-2010, 01:57 PM
jeffro22's Avatar
Originally Posted by joemugg View Post
, what should I do to ensure I don't blow my motor? .
don't run a bullydog.
SCT custom tuning is the best and safest out there and controls your tranny too. but as mentioned Studs and egr delete will be a good thing to do
jeffro22 is offline
post #5 of 11 (permalink) Old 03-06-2010, 04:27 PM
iceman89m's Avatar
First, I would be more concerned with the transmission if your thinking using a Bully Dog...
That is from my personal experience with Bully Dog Triple Dog, I have run the Bully Dog almost 50,000 miles on my truck and the shift to say the least sucks, I have been babying mine since rebuilding the trans till I upgrade to a custom tuned SCT....
As far as the engine goes I havn't had any problem except replacing the injectors due to stiction, No studs or egr delete yet.... still on original head gaskets and egr system with 148,000 miles on the clock
03 6.0 8" Dick Cepek suspension,PJ Dirt Grip 37X14.50X16 mounted on Polished DC-1, 3 1/2" exhaust with 4" core glasspack,Frantz TP Bypass,Bullydog Triple with outlook and AEM Brute Force intake
RIP Will Iott
iceman89m is offline
post #6 of 11 (permalink) Old 03-06-2010, 04:46 PM Thread Starter
Wow, not fans of the BullyDog, huh? In addition to the power, I liked the various info it gave (EGT, OBD codes, trans temp, etc.) Who do you guys recommend for a tuned SCT?
joemugg is offline
post #7 of 11 (permalink) Old 03-07-2010, 07:32 AM
iceman89m's Avatar
I don't belive there would be so many transmission problems with the bully dog if you were running the stock hight tire but I am running a true 37" tall tire. That by its self puts a hell of a lot more load on the transmission.....
The Bully Dog does have some neat stuff, like you say pre and aft turbo EGT at the same time and change on the fly power settings...
I'll make ya a hell of a deal on my Triple Dog Downloader, Outlook Monitor with Piller Pod and 2 EGT Probes if your still thinking of going that way...
RIP Will Iott
post #8 of 11 (permalink) Old 03-07-2010, 07:50 AM
Metal - It kicks your ass
Welcome to the Nation...
Take the advice people give here. It gets expensive paying for your own mistakes. People on PSN know what they are talking about and are very experienced with the PSD. Hence the name "PowerStroke"Nation.
The best thing for you to do from here would utilize the search option. It seems that you may have a little bit of learning to do when it comes your truck.
Modded L99
dirtboy25 is offline
post #9 of 11 (permalink) Old 03-07-2010, 01:08 PM
Stroker67's Avatar
SCT custom Tuned by Eric at Innovative Diesel Performance and ive heard some good things about Matt from Gearhead. EGR delete, headstuds are another good thing, as well as a coolant filter kit, so you can keep your oil cooler unclogged. Oh and some analog gauges to monitor everything.
Stroker67 is offline
post #10 of 11 (permalink) Old 03-07-2010, 06:46 PM
GOOSEKILLER's Avatar
Like said get a SCT there are quite a few good tuners out there, delete the egr, and you will have a good running truck. You can also look into getting your FICM flashed it improves throttle response.
2001 2500 4x4
Built 12 valve
TNT Performance
GOOSEKILLER is offline
