Pushing coolant with fire ringed heads!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-04-2010, 12:32 AM Thread Starter
6oh stroker's Avatar
Iv been runnin innovative tunes for a month now and I just started pushing coolant with fire-rings.... Any one herd of this??? I know innovative has a tendancy of runnin alot of injection timing, has anyone had this issue with idp tunes???
06 250 CC/SB 6 speed
Aeromotive A1000
Aeromotive regulator
Caterpiller filters
SCT tunes from Rcd
Arp's
full egr delete
6oh stroker is offline
post #2 of 10 (permalink) Old 03-04-2010, 12:36 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Pushing coolant with fire ringed heads!!!
Who cut the heads?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 10 (permalink) Old 03-04-2010, 12:41 AM
I havent heard of that, but hopefully it gets figured out for you quick and not costly.
Anthony
2000 F-250 205k Few goodies
avancamp1 is offline
post #4 of 10 (permalink) Old 03-04-2010, 12:46 AM
Extended Power's Avatar
Damn...sorry to hear about your luck.
Chalk up another horror story of people that have used rings and had them fail.
I hope you can get it resolved without it costing a bunch of money.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #5 of 10 (permalink) Old 03-04-2010, 01:04 AM
Proud Sponsor
Abrannan19's Avatar
hmmm..I have heard of it...
Once again, fire rings will not cure all problems that the 6.0 may have...just like studs wont prevent puking..
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #6 of 10 (permalink) Old 03-04-2010, 01:16 AM Thread Starter
Psd... Hypermax cut em.... I'm gunna retorque... And hope for the best... Adam, what have u herd of, rings puking or innovates Tunes runnin high injection timing and cylinder pressure!!!! Thisis just my luck too, right when I blow 630$ on an airdog
Aeromotive A1000
Caterpiller filters
SCT tunes from Rcd
Arp's
full egr delete
post #7 of 10 (permalink) Old 03-04-2010, 02:00 AM
Proud Sponsor
Abrannan19's Avatar
I had rung heads and my truck puked, but I had bottom end issues, it wasn't the gaskets or rings..the problem might not be the rings, whats the oil temp vs. coolant temp
Adam Brannan
Email
post #8 of 10 (permalink) Old 03-04-2010, 02:25 AM
HP Junky
Not all fire ring kits are created equal.
All of the kits WOP has done are still holding great.
RockinJW is offline
post #9 of 10 (permalink) Old 03-04-2010, 02:35 AM
Lovin Life...
02BigD's Avatar
Mmmm...could the procedure for stud torquing have an effect on the quality of hold that a set of rings has?
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #10 of 10 (permalink) Old 03-04-2010, 02:41 AM
HP Junky
I think everything has to work in conjunction perfectly. Getting the perfect amount of crush on that fire ring is vital, you want to effectivley crush that gasket and seal the combustion chamber while not loosing any clamping force on the paper of the gasket. Especially on an engine design that is running just 10 bolts per cylinder. The machining needs to be perfect (WOP prefers to machine all heads in-house), the combination of fire ring size and gasket style are very important as well.
RockinJW is offline
