1/2 throtle injector missing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-04-2010, 12:15 AM Thread Starter
Nastystroke
nastystroke04's Avatar
Just swapped out ficm for a tuned one from eric. The truck starts cutting out about half throtle, any other throtle position it runs fine. Fuel Psi is 60psi, tested voltage on ficm with key on and while cranking 47.8-48.8volts. The truck runs fine with the stock FICM. Any Ideas?
nastystroke04 is offline
post #2 of 6 (permalink) Old 03-04-2010, 01:59 AM
wildfingas @ the org
SuperDutyDon's Avatar
Re: 1/2 throtle injector missing
What are your ICP readings? I had this issue also last month and MY ICP was leaking causing voltage issues. It wasn't throwing any codes for it either. Replaced ICP and fixed the problem.
I cant explain why but any time I tried to accelerate heavy it would cut out like a miss fire.
SuperDutyDon is offline
post #3 of 6 (permalink) Old 03-04-2010, 03:11 AM
<-- Got Air ?
Craig@MPD's Avatar
you need to run a cylinder contribution test most likey its a injector
post #4 of 6 (permalink) Old 03-04-2010, 04:18 AM Thread Starter
Nastystroke
I have not checked the ICP readings yet. When i put the stock FICM back in the truck it runs normal, no miss firing. Still sound like a injector issue?
post #5 of 6 (permalink) Old 03-04-2010, 04:45 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
What RPM is this at? Cylinder contribution test only works in the lower rpm region less than 1800 IIRC.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #6 of 6 (permalink) Old 03-04-2010, 09:15 PM
motoxracer42's Avatar
are you sure the plugs are all the way in. did you bend any prongs on the ficm. the only time i ever had mine cut out at about 2000 rpm was a spool valve. i replaced it and everything was fine. its weird that it only does it with erics ficm.
06 crew cab
06 reg cab
motoxracer42 is offline
