My time has come! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-03-2010, 05:31 AM Thread Starter
05Excursion's Avatar
My time has come!
The time for my truck has finally come! I'm getting studs,new EGR cooler(new smog laws),oil cooler, and a 4 guage pillar, but I'm wondering if anyone has any more input on what else can be done while everything is apart. I know this subject has been brought up a few times but it seems we always learn something new every few weeks. I'm not doing a fuel system because I'm keeping stock injectors and I'm primarily towing, and I've heard mixed information on reliability. Anything you guys can think of(that doesn't cost a fortune,getting new tires to the tune of about $1600 too), just give the info. I'm sure the guys doing my studs with all the experience they have will have some input as well, but I figure the more people chime in the better!!
2005 Excursion Limited,6" lift,35 Toyo Mt's,4.33posi,S&B intake, 4" straight pipe, coolant filter,ARP's, 4 guage pillar, gear head tunes, Powermax Stage 1 Turbo
05Excursion is offline
post #2 of 11 (permalink) Old 03-03-2010, 12:21 PM
Brentos's Avatar
Re: My time has come!
either exhaust or a oil filter relocation /bypass filtration kit
Brentos is offline
post #3 of 11 (permalink) Old 03-03-2010, 02:37 PM
elite has a coolant recirculation hose that taps into both heads to keep the heads cool. it can only be done with the geads off
halerazor is offline
post #4 of 11 (permalink) Old 03-03-2010, 05:04 PM Thread Starter
Ok, I have a 4" exhaust and do those coolant lines really help? I mean it makes sense, but how many have used it?
post #5 of 11 (permalink) Old 03-03-2010, 08:06 PM
Brentos's Avatar
Mine is just fine without it so you will be to
Brentos is offline
post #6 of 11 (permalink) Old 03-03-2010, 08:14 PM
Monkeys have armpits!
Sprman's Avatar
you can do a crossover line for the fuel. Trusted performance has a great kit. i have it on my truck. It can be done with the cab on, but its a LOT easier if the cab is off.
2005 F-250 FX4 CC
bought it, then changed it.
Sprman is offline
post #7 of 11 (permalink) Old 03-04-2010, 05:34 AM Thread Starter
That looks like a good kit. Anything else anybody can think of? It goes in tomorrow morning so keep the suggestions coming!
post #8 of 11 (permalink) Old 03-05-2010, 03:41 PM
Diesel Enthusiast
MikeDually's Avatar
Sorry to hear you to put a new EGR cooler on.
You mentioned new smog laws, do they actually look under the cooler and vale to see that it is functioning? How do they do that?
05 CC LB DRW
Studs, Full EGR Delete First Coast, SCT, MBRP 4" Straight, IssPros
MikeDually is offline
post #9 of 11 (permalink) Old 03-06-2010, 02:24 AM
GS247's Avatar
i had this done to mine too, it also ties into my coolant filtration kit.
here are a few pics from when mine were done. you can see the silver AN fitting by the flex pipe.
here is the other with a blue AN tee that gets tied into the coolant filter
03 EB EXcursion 6.0L
AFE intake
Edge Juice W/Attitude (gauges only)
Glow Shift Oil, Coolant, & Trans temp gauges
SCT X3 w/ xtreme street from Innovative
MBRP 4" turbo back
ARP studs
Jefferson State Diesel Coolant Filtration System
FICM modded by Jefferson State Diesel
Slotted brake rotors (front)
Mag-Hytec trans pan
GS247 is offline
post #10 of 11 (permalink) Old 03-06-2010, 04:37 AM Thread Starter
They don't look under the cooler, but they are planning to scan the truck to see if the EGR valve is working(I'll have it turned off the rest of the year) and it has to see exhaust to work and not set off a DTC or check engine light from coming on, and that will fail the smog test.
