Tuned FICM - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-02-2010, 03:15 AM Thread Starter
Nastystroke
nastystroke04's Avatar
Tuned FICM
Just installed my tuned FICM from Eric. Truck has been sitting for about a week in cold weather (teens at night, 30-40 during the day). The question i have is after the install should the truck be hard to start? The truck is running after 4 long cranks (30sec).
nastystroke04 is offline
post #2 of 19 (permalink) Old 03-02-2010, 06:33 AM
Hate 'R Us
!!!PainTrain!!!'s Avatar
Re: Tuned FICM
Rough cold starts have proven to be normal for trucks with a FICM tune.
!!!PainTrain!!! is offline
post #3 of 19 (permalink) Old 03-02-2010, 01:08 PM Thread Starter
Nastystroke
Re: Tuned FICM
Thanks paintrain. I thought i saw that somewhere on here but couldnt find it through the search.
post #4 of 19 (permalink) Old 03-02-2010, 03:37 PM
GOOSEKILLER's Avatar
Re: Tuned FICM
When you get your FICM flashed eric takes out the heat inductive flash and that's why it starts like that. I am pretty sure that's what its called. I put rev x in my truck and it starts a whole lot better so you might wanna try that.
2001 2500 4x4
Built 12 valve
TNT Performance
GOOSEKILLER is offline
post #5 of 19 (permalink) Old 03-02-2010, 03:47 PM
SamW's Avatar
Re: Tuned FICM
Just use synthetic 5w40 next oil change. made a bigger difference then adding rev-x to regular 15w40. Cheaper too. Mine would barely start with eric's ficm tuning and less then 50 degrees.
2006 F250 CCSB
6.
SamW is offline
post #6 of 19 (permalink) Old 03-02-2010, 04:22 PM Thread Starter
Nastystroke
Re: Tuned FICM
Thanks for the info! I just changed my oil so i might use some rev x until next time, then use 5w40.
post #7 of 19 (permalink) Old 03-02-2010, 07:02 PM
Re: Tuned FICM
Yea i also use Valvoline extreme 5w40
2001 2500 4x4
Built 12 valve
TNT Performance
post #8 of 19 (permalink) Old 03-03-2010, 04:44 PM
RWx4
ImNachenSein1160's Avatar
Send a message via AIM to ImNachenSein1160
Re: Tuned FICM
i have the same problem with similar temps. I just plug it in with a timer. if it comes on about 30mins to 1hr before I plan to take the truck it starts right up.
2004 F-350 DRW 6.0L 5SpDauto Lariat LE
ImNachenSein1160 is offline
post #9 of 19 (permalink) Old 03-04-2010, 02:11 PM
jeffro22's Avatar
Re: Tuned FICM
my truck has been cold starting like crap and chugging white smoke for about 30 seconds until warmed up running a tuned FICM. The rest of the day it starts normal though. I am running 15w-40 now, but almost always run 5w-50 sysnthetic. Will be switching soon to see if that helps.
jeffro22 is offline
post #10 of 19 (permalink) Old 03-04-2010, 02:26 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: Tuned FICM
I believe PHP adds the inductive heat flash to tuned FICMS. Not 100 percent sure thought they did. I might try that out someday.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
