egr delete still runs slugish/ANY IDEAS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-28-2010, 04:47 PM Thread Starter
I took it to ford and they said i need a new EGR cooler. So i put a EGR delete kit and it didnt fix the slugishness. At idle its fine. When I rev it up to 1500 or 2000 RPM it sounds like its missing and rocks the truck and smokes like its dumping gas... I also jus had a new FICM put in and reprogramed To fix my hard start and rough idle. ANY IDEAS????
2004f250 is offline
post #2 of 8 (permalink) Old 02-28-2010, 09:36 PM
Stroker67's Avatar
Re: egr delete still runs slugish/ANY IDEAS?
Did you do a full delete or just block off plates?
Stroker67 is offline
post #3 of 8 (permalink) Old 02-28-2010, 10:54 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
What is the exact RPM that it starts shaking at? It will help you figure out if you need check valves in the high pressure system, or if you have combustion leaking into the fuel system.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 8 (permalink) Old 03-01-2010, 05:28 PM
Slated4Greatness's Avatar
Did they check the injectors as well?
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #5 of 8 (permalink) Old 03-09-2010, 04:14 AM
do you have a boost gauge? that would help to diagnose the issue.
you could have a sticky turbo actuator
350oilburner is offline
post #6 of 8 (permalink) Old 03-09-2010, 04:19 PM
PETE ENGR PSD
Sounds like you found another bad ford stealership.
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #7 of 8 (permalink) Old 03-27-2010, 05:36 PM
Iam new to the diesel trucks but mine had that same problem and it was the ICP sensor.
kris81 is offline
post #8 of 8 (permalink) Old 03-27-2010, 09:14 PM
Proud Sponsor
Abrannan19's Avatar
when mine was doing that I had a couple injectors that were allowing combustion past them.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
