2003 F-350 w/ CAT C7 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-25-2010, 06:45 PM Thread Starter
PA 6.0 PS
OutlawSmoke's Avatar
Anyone have any idea if it would be possible to "beef up" a front end enough to hand a Twin Turbo Caterpillar C7? Might have a lead on a setup and I am thinking of picking up another rig to put this setup in.....Any ideas, feedback, ect.?
OutlawSmoke is offline
post #2 of 10 (permalink) Old 02-25-2010, 06:50 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: 2003 F-350 w/ CAT C7
How does the C7 compare dimension and weight wise to an 8.3l cummins??
There is a guy on here whose boss has an F350 with a 8.3L shoehorned in. He posted up pics and all somehwere on here. Took some mods all around to get it to fit, but if the C7 is close in size then maybe it will work.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #3 of 10 (permalink) Old 02-25-2010, 06:57 PM Thread Starter
PA 6.0 PS
Not sure on the overall dimesions....that I am betting that the length of the engine compartment might be an issue....with a set of electric fans, maybe it would pick up enough....everything I have always heard was with the overall weight and the front end not being able to handle it.....
post #4 of 10 (permalink) Old 02-25-2010, 07:00 PM
<---- Funny
wriott's Avatar
the weight is a small issue, placement is the biggest concern. also you have to check into seeing what transmissions will fit the motor, then check to see what will need to be modded on the truck to make it work
Will
2002 F-350 CC LB 4x4 DRW
3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks
Random pics
wriott is offline
post #5 of 10 (permalink) Old 02-25-2010, 07:12 PM Thread Starter
PA 6.0 PS
was thinking maybe an allison with an adapter plate.....possibly an ATS.
post #6 of 10 (permalink) Old 02-25-2010, 07:18 PM
uga33's Avatar
People are doing 466 conversions, I don't see why a C7 wouldn't fit. Lots of firewall modification is needed!
uga33 is offline
post #7 of 10 (permalink) Old 02-25-2010, 07:21 PM
<---- Funny
wriott's Avatar
i belive they make allison autos that mate up directly to the motor.... only a BUILT pickup motor will last behind one of these
Will
Random pics
wriott is offline
post #8 of 10 (permalink) Old 02-25-2010, 08:18 PM
REDSOX2758's Avatar
Now THIS would be cool! Keep us updated...
2004 F-250 6.0
117,XXX miles
05 front end conversion
Innovative's SCT tunes
ISSPRO EV LED gauges
7 inch single... straight piped
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
Best 1/4 - 13.96 at 95.46 MPH
REDSOX2758 is offline
post #9 of 10 (permalink) Old 02-25-2010, 11:00 PM
6Leaker
jdc753's Avatar
took a lot of searching but I finally found it...
Its an 8.9L ISL not an 8.3L
Pics...
Precious pictures from trucks photos on webshots
Some discussion and details on the truck
Smokey Reds 8.9L Cummins Superduty - Powerstroke Nation
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #10 of 10 (permalink) Old 02-26-2010, 02:35 AM
Still learning
bad moose's Avatar
Here are the specs for the c7 Cat.
http://www.meadowlandford.com/cat-engine-c7.pdf
I don't think size will be much of an issue probally the weight is the biggest factor.
Check into Eaton for trans or Allison.
Should be cool if you do it. Keep us posted
03 F250 King Ranch
SCT tuned by Eric @ Innovative, Exhaust, and Air Raid filter
EGR Deleted
Still to slow
bad moose is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/11-6-0l-power-stroke-aftermarket-performance/53847-2003-f-350-w-cat-c7.html
Posted By For Type Date
Engine Conversion to Cat C7 - Ford Truck Enthusiasts Forums This thread Refback 10-27-2015 10:59 PM
