coolant temp sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-23-2010, 10:57 PM Thread Starter
trucknut56's Avatar
coolant temp sensor
Im in the process of doing an electric cooling fan setup on my 06 6.0. What is the ideal operating temp for these trucks and where would I put the new sensor for the fans? Ill be running duel spal 16 inch fans with a programmable controller. The reason im going with electric fans is cause of the rules for the pro mod pulling class up here, no engine driven fans allowed.
trucknut56 is offline
post #2 of 11 (permalink) Old 02-23-2010, 11:09 PM
Brentos's Avatar
Re: coolant temp sensor
ideal is 180-190 you could drill and tap the radiator if ya wanted about the easiest place IMO
Brentos is offline
post #3 of 11 (permalink) Old 02-23-2010, 11:14 PM Thread Starter
trucknut56's Avatar
Would you have the fans come on at 190 then off at 180? I have always heard that the head is the best place for the sensor but im thinking that would be a bit difficult
post #4 of 11 (permalink) Old 02-23-2010, 11:15 PM
06powerstroke's Avatar
I put the sender for my coolant temp gauge in a port in the side of the block, could this be a good place for the OP to mount the sensor for the fans? It's easier than drilling and taping, you just need a metric to 1/8th NPT adapter (assuming the new sensor is 1/8 NPT).
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #5 of 11 (permalink) Old 02-23-2010, 11:24 PM Thread Starter
trucknut56's Avatar
You beat me to it, I was just going to ask that as I just read a thread about that topic that was posted awhile back
post #6 of 11 (permalink) Old 02-23-2010, 11:38 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
A great place to drill and tap is in the cap on the oil cooler coolant outlet.
The thermostat starts to open at 190. Its full open around 220.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 11 (permalink) Old 02-24-2010, 12:57 AM
Proud Sponsor
Abrannan19's Avatar
yep, George got that idea from us..its a good location, mine works great.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #8 of 11 (permalink) Old 02-25-2010, 12:13 AM
Diesel Enthusiast
MikeDually's Avatar
I'm using the extra ports on the coolant filter housing. I've had it there for a little over the year and seems pretty consistent.
05 CC LB DRW
Studs, Full EGR Delete First Coast, SCT, MBRP 4" Straight, IssPros
MikeDually is offline
post #9 of 11 (permalink) Old 02-25-2010, 02:36 AM Thread Starter
trucknut56's Avatar
Thanks for all the input guys, ill be running the sensor in the oil cooler coolant outlet, looks like a pretty good place for it
post #10 of 11 (permalink) Old 02-27-2010, 05:05 AM
cshsrh's Avatar
AdaM THAT is where your temp sensor for your gauge is correct....Is it as easy as just unbolting drill/tap and reinstalling?? I am running autometer's
cshsrh is offline
