Studs installed without Cab lifted off?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-22-2010, 12:05 AM Thread Starter
05Excursion's Avatar
Alright, I've been hearing for a while that some shops are installing head studs in 6.0's without having to lift off the cab? Has anyone had it done to their truck and how are they holding up? Any mechanics utilizing this method? Any pros or cons? I have an Excursion and I'm thinking about doing them next month and I'm wondering if the technique works and how its done.
2005 Excursion Limited,6" lift,35 Toyo Mt's,4.33posi,S&B intake, 4" straight pipe, coolant filter,ARP's, 4 guage pillar, gear head tunes, Powermax Stage 1 Turbo
05Excursion is offline
post #2 of 12 (permalink) Old 02-22-2010, 02:02 AM
Busy Busy
Marty's Avatar
Re: Studs installed without Cab lifted off??
It works but it sucks. Lifting the cab or pulling the engine in your case would probabl be easier.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 12 (permalink) Old 02-22-2010, 02:30 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
I have seen an excursion body off. Buddy of mine did it on his personal truck just to do it.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 12 (permalink) Old 02-22-2010, 03:12 AM
Just did my 05 F-250 pulled the engine to do it. Once you lift the front of the cab up it gets you tons of room to lift the engine out, I even put the turbo and exhaust on to reinstall it. Only undid the mount bolts on the fenders and under the front d/s and p/s, then used two jacks and 4x4s worked good! Hardest part was lining up the flywheel and torque studs for reinstallation
Jamie
jzamluk is offline
post #5 of 12 (permalink) Old 02-22-2010, 03:20 AM Thread Starter
So is it possible to install the studs without lifting the cab or pulling out the motor? If so, why aern't more shops using that technique?
post #6 of 12 (permalink) Old 02-22-2010, 03:26 AM
fueled by Colecovision
golfer's Avatar
Garage
one of our mechanics did 2 cab on stud installs last week..
it's about a 10-12hr job per truck with the cab on.
golfer is offline
post #7 of 12 (permalink) Old 02-22-2010, 10:27 AM
HarleyEdition78412's Avatar
Cool Re: Studs installed without Cab lifted off??
Because what pays more- doing studs or removing the cab and then doing studs?
But then most also pull the head for machining and HGs so that's another argument for either pulling cab or engine.
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #8 of 12 (permalink) Old 02-22-2010, 01:39 PM Thread Starter
So is it safe to say that you can put the studs in but can't change the head gasket or get the heads out for machining?
post #9 of 12 (permalink) Old 02-22-2010, 02:01 PM
It can be done, but it's not much fun I'm guessing. There are a few write-ups here and there on this forum and other.
2005 F-350 XL CC LB 4x4
Auto, SCT, Tunes from Eric, 03 Turbo, Exhaust, Coolant filter
2008 F-250 XLT CC SB 4x4
6.4 Auto, 6in Procomp lift, 37x12.50r20
Originally Posted by yogi7615 View Post
Unfortunately, there are too many animals wanting handouts and too many bleeders willing to give away other peoples money that it won't be easy to remove the stupid one.
willholl79 is offline
post #10 of 12 (permalink) Old 02-22-2010, 02:20 PM
young buck learning.
03International's Avatar
good question. ive always wondered this myself.
03International is offline
