AFE intake with a Spectre filter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-31-2017, 01:03 AM Thread Starter
PSChad's Avatar
Exclamation AFE intake with a Spectre filter?
Hey guys,
I recently purchased this 6.0 (picture in avatar) and i noticed it had a afe intake "stage 2", I believe installed. From the brand on the intake and heat guard and from what I've seen in pictures online.
My question.....
I didn't notice this before but I spun the air filter and saw that its a AFE intake set up with a Spectre filter on it!!! (SEE ATTACHED PIC)
Now, coming from the 7.3 and having a 6637 napa filter on mine - i'm not too familiar with cold air intake set ups on these. I do not have the stock set up as its been removed previous to me or i'd put that back in from what I have seen recommended in other posts.
Occationally at WOT when i'm messing about the air flow sensor will come on (yellow arrow thing in the top right). Is this because this cheap filter isn't allowing enough air flow? Can I leave this filter on? Whats the deal?
Is there a better one I can pick up local?
Thanks!
PSChad is offline
post #2 of 4 (permalink) Old 08-31-2017, 12:28 PM
Scherf's Avatar
Garage
Re: AFE intake with a Spectre filter?
is the MAF sensor clean? also if that filter is coated in oil (like a K&N), too much oil can cause a MAF code due to it becoming dirty, then the oil being sucked off it latter causing the light to go away. i over oiled mine one time and that is how i solved it.
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #3 of 4 (permalink) Old 08-31-2017, 12:46 PM Thread Starter
PSChad's Avatar
It is not a oiled filter and seems to be new and very clean.
Sensors seen to be fine also.
I'm assuming this filter sucks balls?
PSChad is offline
post #4 of 4 (permalink) Old 08-31-2017, 01:26 PM
Scherf's Avatar
Garage
could be... did you pull and clean the sensor though? and if you did, then i would look at the next cheapest step, meaning trouble shooting the wires, then either a MAF sensor or filter, what ever is cheapest IMO
but for the record, any "need for speed" part like that, coming off a shelf at an auto parts store are usually always junk.
Scherf is offline
