Worth the effort? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-20-2017, 05:58 PM Thread Starter
6 Piston Power's Avatar
Worth the effort?
I'm tossing around ideas here but am looking for a way out of working my life away for someone else. With this in mind, what would one expect to invest for a motor swap?
How do you inspect the transmission for damage from potential improper hot rodding?
https://waterloo.craigslist.org/cto/...262565396.html
What would you pay for this vehicle once the swap was completed correctly?
6 Piston Power is offline
post #2 of 3 (permalink) Old 08-20-2017, 06:21 PM
Ruben72's Avatar
Garage
Re: Worth the effort?
I would look at the truck first and if anything offer 2000 since it's not running. Pull the transmission dip stick out and smell the fluid and if it smells burnt transmission is probably on the way out. If the body isn't bad probably closer to 8k or 10k. You can find a used engine for about 3k to 6k you can find them on the internet I just found one on eBay for 1,900
Sent from my XT1650 using Tapatalk
Ruben72 is offline
post #3 of 3 (permalink) Old 08-20-2017, 06:31 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
I do not think it would be worth it. You'll plan it out in your head that you'll spend x amount getting it running, but its likely going to be notably more. You'll run into problems and wish you could hit the rest button. I would save up my $$ and buy a nice 6.0 that wasn't a work truck and has fewer miles.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
