tuned HPOP pressures 6.0 questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-20-2010, 12:13 PM Thread Starter
jrmmustang's Avatar
Well last night I had a friend hook his scanner up to my truck to do some real time data.
I was running innovatives x-street tune.
I guess i have a few questions on the info we found. The first was he icp pressure the desired was 1780 and it met it and the duty cycle was 80%. I thought that that seemed a little low. Most people talk about the pressures to be in the upper 2000's psi.
2003 F-350 Crew 4x4 205k 4" silverline turbo back CAI, Garret Stage One VGT, 165cc injectors, SCT ID's x-race x-street tow
jrmmustang is offline
post #2 of 17 (permalink) Old 02-20-2010, 01:57 PM
PETE ENGR PSD
Re: tuned HPOP pressures 6.0 questions
I know to crank, the system requires 500 psi iirc.
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #3 of 17 (permalink) Old 02-20-2010, 04:45 PM
Brentos's Avatar
should be around 4k WOT
Brentos is offline
post #4 of 17 (permalink) Old 02-20-2010, 05:19 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Not always.
I would be less concerned with the psi number and more concerned with the voltage of the sensor. Trying to get it as close to 5 volts as possible.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #5 of 17 (permalink) Old 02-20-2010, 05:59 PM
Turbo99's Avatar
you will not see what the ICP actually is on the scanner because of programming w/ Erics tunes, to see you will have to put a mechanical gauge on it. 1780 is all you will see w/ the scanner on Erics tunes.
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #6 of 17 (permalink) Old 02-20-2010, 07:25 PM
motoxracer42's Avatar
yup scanner wont read it correctly with some tunes.
06 crew cab
06 reg cab
motoxracer42 is offline
post #7 of 17 (permalink) Old 02-20-2010, 08:12 PM
Captain Negativity!
PSDPlayer's Avatar
It's reading what its told. It's reading correctly. But it has been rescaled.
Email:
post #8 of 17 (permalink) Old 02-20-2010, 08:23 PM
Turbo99's Avatar
Sometimes it seems like you post just to be posting.
Its not reading actual pressure so therefore it is NOT CORRECT it may be reading what its told but it is told a bogus number....1 doesnot = 1 in this case. So instead of trying to talk circles like you have some inside track on something just answer the mans question, even if he wasn't completely clear on we all knew what he was asking.
Jeremy
Turbo99 is offline
post #9 of 17 (permalink) Old 02-20-2010, 08:36 PM
Captain Negativity!
PSDPlayer's Avatar
I did answer his question. It is reading the rescaled voltage to MPa table in the processor. 4000 has become whatever it has been rescaled to in the tune. But the tables in the tune are in MPa. So 28MPa which was ~4061PSI is now being desired as 12MPa. 28 has become 12.
It is reading CORRECTLY since the computer only sees VOLTAGE. And then converts that into an MPa number for the PID display on the scan tool.
So a mechanical gauge is NOT needed. Since the sensor is telling you that it is getting the pressure you want since the VOLTAGE is where it needs to be.
Email:
post #10 of 17 (permalink) Old 02-20-2010, 08:42 PM
Turbo99's Avatar
but seeing how he doesn't know that....not being a tuner the scan tool is showing in a PSI value that is not what the truck is seeing............end of story.
Jeremy
Turbo99 is offline
