Head Gaskets - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-20-2010, 01:57 AM Thread Starter
GOOSEKILLER's Avatar
Head Gaskets
My truck has been studded and it has a blocker plate on the egr and this mornin on the way to work it puked out all of the coolant. I put coolant back in and put my truck back to stock and it did it on the way home just not as bad. When my truck got the studs installed he replaced the heads with new ones. Do you think i blew my head gaskets again it is coming out of the degas bottle? WTF!!
2001 2500 4x4
Built 12 valve
TNT Performance
GOOSEKILLER is offline
post #2 of 11 (permalink) Old 02-20-2010, 04:43 AM
Re: Head Gaskets
Define "blocker plate" for us. Do you just have a plate in the up pipe to block exhaust to the cooler? Something probably happend to the EGR cooler if it is still there.
BoredandStroked is offline
post #3 of 11 (permalink) Old 02-20-2010, 10:21 AM Thread Starter
Re: Head Gaskets
Yea i have a plate to block exhaust to the cooler
2001 2500 4x4
Built 12 valve
TNT Performance
post #4 of 11 (permalink) Old 02-21-2010, 01:43 PM
Re: Head Gaskets
Pull the EGR valve to see if it is wet from coolant.
04 F250 FX4 CC SB 6.0 PSD Torqshift
Exhaust, RCD 62mm, 155/75 Injectors, PCM & FICM tuned by Eric, EGR Delete, ARPs, Dashdaq, Banks Intercooler
kruser02 is offline
post #5 of 11 (permalink) Old 02-21-2010, 01:56 PM
Stroker67's Avatar
Re: Head Gaskets
Have you thought about deleting the EGR? Or do you live in a commie state that does emissions testing?
Stroker67 is offline
post #6 of 11 (permalink) Old 02-21-2010, 03:15 PM
Sponsor
97singlecab's Avatar
Re: Head Gaskets
Check your egr valve for wetness. You also need to check your oil cooler as well. When it gets plugged it will flash boil the coolant causing it to puke.
Mike Haller
Haller's Repair (307) 778-8880
RUNNIN BROKE RACING
Now offering mobile dyno services. Call today to set up your next event or get together.
97singlecab is offline
post #7 of 11 (permalink) Old 02-21-2010, 03:42 PM Thread Starter
Re: Head Gaskets
I just orderd an intake manifold from GoGo diesel. This might be a stupid question but how can the egr still fail if i have a plate blocking it?
2001 2500 4x4
Built 12 valve
TNT Performance
post #8 of 11 (permalink) Old 02-21-2010, 03:49 PM
it's an 02 05 08
turbodiesel_02's Avatar
Re: Head Gaskets
like 97 singlecab said pull your egr valve and check for wetness probably wouldnt hurt to clean it,then i would look at what temps your oil and coolant are running at
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #9 of 11 (permalink) Old 02-21-2010, 03:56 PM
Re: Head Gaskets
The blocker plate is not a complete seal, it will still push air past it under a hard boost, Like they said check the egr valve,jack the back of the truck up about a foot or two this compensates for the engine leaning to back and pop the egr valve. If you have access to a scanner check the engine oil temp verses the coolant temp. 20 degress I THINK and more of a difference than you have a bad cooler
03 f-250 6.0 tec3 programming.. Running all of power hungry performance handy work, plus i work there.
georgia diesel is offline
post #10 of 11 (permalink) Old 02-22-2010, 02:37 PM
DBM
DBM's Avatar
Re: Head Gaskets
wouldn't you still get white smoke or steam out the exhaust, or would having tunes or unpluging the egr valve prevent that?
DBM is offline
