2007 5R110 P0751 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Scott M
post #1 of 8 (permalink) Old 06-30-2017, 12:41 AM Thread Starter
2007 5R110 P0751
Hey guys I'm having some issues with my transmission. Just within the past couple of days I have been having some problems with a delayed/harsh engagement in drive and reverse and at the 2-3 shift it will flare and bang until it makes the shift. And 3-5 will flare then shift extremely hard. I have been running the extreme street tune for about 60 miles now. I am currently at 98k. Just today the tow/haul light flashed and I pulled codes and had a P0751. I believe it's for SSA. I have read about the improved direct clutch solenoid. Has anyone installed this to fix this issue? Anyone have any ideas on this one? Hoping I don't have to pull the trans. Truck has no performance upgrades other than the tune... which I loaded the stock one back in and am still having issues.
2007 F250 SCLB. Studs, EGR delete, MBRP 4" turbo back exhaust, SCT w/ custom tunes
coal_burner07 is offline
post #2 of 8 (permalink) Old 06-30-2017, 11:44 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 2007 5R110 P0751
If you install a new direct clutch solenoid I can gaurantee that you will still have a code P0751. That code is for the coast clutch solenoid, not the direct clutch.
This solenoid is not involved with the 2-3 or the 3-5 shift, unless your tune is doing something strange and turning it on.
When you installed the tune did you clear the memory? If not, the adaptive software may be way out of whack which will cause 2-3 and 3-5 shift problems.
Mark
Mark Kovalsky is offline
post #3 of 8 (permalink) Old 07-01-2017, 01:47 AM Thread Starter
Yeah I looked into it a little more and your right the code is for SSPC-A. I ordered one from ford and will be installing it tomorrow. I'm praying I don't find metal when I pull the pan. Very odd it would flag that code when I'm having the 2-3, 3-5 symptoms.
As far as the tune, I've been running that same tune for about 60k now.... sorry I mis wrote that in the original post.
post #4 of 8 (permalink) Old 07-01-2017, 10:53 AM
Master BS'er
jamiesaun's Avatar
So now we have coast clutches? I have never even heard of a coast clutch.
It's ridiculous how much this stuff changes.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 8 (permalink) Old 07-01-2017, 12:42 PM
The E4OD had a coast clutch when it debuted in 1988. The 4R100 had a coast clutch, too.
Mark
post #6 of 8 (permalink) Old 07-01-2017, 07:46 PM Thread Starter
So I went into work today, pulled the pan to change SSPC-A and there was a pretty good
Amount of metal in the pan. If you ran your finger over the filter opening it looked like you touched anti seize. So looks like it's time for the trans to come out. I don't know how this could have happened... I'll be honest I never really work the truck... no towing or plowing. I don't beat it either. I kept up on changing the fluid and filters. I ran the extreme street tune from innovative for the last 60k but like I said I don't beat on it and drive it like an old man 80% of the time.
post #7 of 8 (permalink) Old 07-05-2017, 02:43 PM
Scott M's Avatar
Just curious as to how many miles total are on the truck and or transmission? Not that it does anything for you just was trying to gather info.
6ohstroken likes this.
04 F350 King Ranch Fx4 Leveling Kit
Atlas 40, 4" SP, ARP Studs, EGR Delete,SCT Livewire
20x10 Novakanes/325/60 Nitto G2s
Scott M is offline
post #8 of 8 (permalink) Old 07-06-2017, 12:05 AM Thread Starter
Just shy of 100k miles
