'05 Excursion gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-24-2017, 05:09 AM Thread Starter
Newb? Where?
KneeDragger79's Avatar
So I have a 2005 Excursion 6.0L and it has been awesome after "bullet-proofing" the motor. My next endeavor is running Waste Vegetable Oil and I need a place for more gauges.
There are four on the pillar; turbo boost, fuel psi, trans temperature and a pyrometer. Running WVO I need a oil (fuel) level and coolant temperature. I would really like to have an engine oil temperature gauge as well.
This project has been in my mind for many years. I thought there was a three gauge pod that went on top of the dash but I cannot seem to find it. So with the help of the members on this forum I hope to get some help. I would be very appreciative.
Thanks for the help Power Stroke Nation!
2003 F250 6.0L - Black Onyx gaskets, ARP head studs, BulletProof Diesel EGR delete, BulletProof Diesel oil bypass filters, BulletProof oil cooler delete kit, Driven Diesel regulated return kit, O-ringed cylinder heads
2005 Excursion 6.0L - OEM factory head gaskets and ARP head studs
KneeDragger79 is offline
post #2 of 2 (permalink) Old 05-24-2017, 12:29 PM
Moderator
Sbluke55's Avatar
Re: '05 Excursion gauges
I personally would run the cts2. It can be configured to monitor all of the stuff you want. Including the 4 gauges you already have.
If you want analog gauges. I would do the pod that goes above the rear view mirror or the f650 lower dash from riff raft
01 f-250, Standard
Sbluke55 is online now
