White smoke with the smell of diesel fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-15-2017, 09:47 PM Thread Starter
Scherf's Avatar
Garage
ok i need some help, i am at a complete loss and have been reading for days with no real answer.
i have an 04 with no major modifications, it has recently been bulletproofed with brand new heads and that is it. my truck has 193,xxx miles.
last week i threw an injector, #2 to be exact. i have pulled it replaced it, started it, then the #1 went out, i then replaced that one. BOTH INJECTORS CAME STRAIGHT FROM FORD, NO REMAN INJECTORS.
now after replacing the #1 it is throwing a cylinder imbalance #2 again (p0266). and i cannot figure out why. the motor when running has a slight rough idle and rolls white smoke that smells like diesel fuel. no sweet smell like coolant and no blue tint like oil. i tried to compression test the motor but the kit i bought doesn't have a fitting for the motor.
FICM HAS BEEN TESTED and i am putting out 50 volts at all times. the lowest it got was 48v during cranking.
i have seen that the 04 had injector harness issues due to how it was routed, and i have poked around to see if that would make a worse idle or smooth it out. no such luck.
the only codes thrown is the p0266 and a few for glow plugs due to the modulator for them is bad on two unrelated cylinders....
any advice will be much appreciated!
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
post #2 of 2 (permalink) Old 06-13-2017, 02:58 AM Thread Starter
Scherf's Avatar
Garage
Re: White smoke with the smell of diesel fuel
ok so i put an actual computer reader (Snap-On). come to find out, the FICM is at fault... even doing a bench test of it on the truck, you can still get a false positive. the FICM should base line at 48V but should continue to build to the actual injector, up to anywhere from 70 to 100V
Scherf is offline
