Gasket set for long block build. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-24-2017, 11:51 PM Thread Starter
Going to tackle a long block on my 06 F350. Does anyone know of a good gasket set for a long block build, and any advise on parts or anything I should do while the engine is out? Any and all help is appreciated.
Thanks
Bruce
brudavis1031 is offline
post #2 of 4 (permalink) Old 04-25-2017, 01:00 AM
Re: Gasket set for long block build.
Ford parts
Shuey is offline
post #3 of 4 (permalink) Old 04-25-2017, 04:08 AM
Ruben72's Avatar
Garage
Either ford or mahle gskts kit I've used both. Reseal the bed plate if it appears to be leaking. Updated STC fitting. Updated stand pips and dummy plugs. Blue spring fuel regulator. ARP head studs, oil cooler, bulletproof EGR cooler or delete. Remove the water pump from the front cover and see if there is any cavitation behind the pump.
Sent from my XT1650 using Tapatalk
Ruben72 is offline
post #4 of 4 (permalink) Old 04-25-2017, 09:32 PM Thread Starter
Thanks guys. anyone else have advice.
