6.0L Head Stud Installation Cab Off Method.(How To) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-09-2008, 03:47 AM Thread Starter
SUPERIOR OFFROAD INC.'s Avatar
Ok, I know that there is alot of knowlegable people on this site so i want to start this thread off right. I want to use this post for the sole purpose of a DIY head stud/head gasket removal/installation. I know that there is alot of details here folks so lets be patient and correct in our directions to do this very needed task on all of our loved 6.0L's. Without the high price of a shop. And please let's not make this a send to local shop pay $$$ thread as that is not what everyone is looking for. Any tips or shortcuts will be greatly appreciated as well. Thanks in advace everyone.
2011 6.7 yet to be ####ed with.... Yet...
SUPERIOR OFFROAD INC. is offline
post #2 of 10 (permalink) Old 01-09-2008, 04:25 AM
Super Moderator
weweld's Avatar
Re: 6.0L Head Stud Installation Cab Off Method.(How To)
For those who don't have access to a hoist but can get a fork lift here is what I did
http://www.socaps.com/photopost/show...php/photo/3626
http://www.socaps.com/photopost/show...php/photo/3658
It is very easy to build and only took me a few hours , most of the steel came from a scrap and salvage yard.
If you live close to me you can borrow it for free , it will do a reg ,super or crew cab.
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #3 of 10 (permalink) Old 01-09-2008, 05:24 AM
Sponsor
Logan21SV's Avatar
nice gene, where does that grab on the bottom? pinch weld? how is ur cage designed to allow the cab to come off.
the way i do it is, use a 2 post lift? main things to watch out for are the ground straps, steering linkage, parking break cable.
CenTexDiesel.com
Logan Schneider
830-885-6500
Logan21SV is offline
post #4 of 10 (permalink) Old 01-09-2008, 05:58 AM
Super Moderator
weweld's Avatar
Uses to same holes as the running boards do
The roll bar bolts to the frame on 8 mounting plates and bars are welded to the floor of the cab and a slot in the bed.
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #5 of 10 (permalink) Old 01-09-2008, 03:28 PM
Hope I don't get flamed here, but I can't count how many of these our shop has done. I can't afford to loose a hoist while the headgasket jobs are completed so we don't take the cab off. We do loosen the cab mounts and lift the cab maybe 2-3 inches. We then loosen rear trans mount and tip the engine forward. The only clearance issues are on the number 8 cylinder removing the old bolt and installing the stud. That is the only reason we do the cab mounts and loosen the trans mount. We also remove the a/c, heater housing, looks like a nightmare but it is actually easy. From there we just start removing the front of the truck, bumpers, lights, condensor, radiator ect. For the DIY guy just remember to tape up all the a/c connections as to not allow moisture contamination, otherwise you'll be replacing reciever drier. Then it's off to the intake plenum, then the turbo. From there it's time to start heading into the heads. I do require my guys to pull the injectors, not necessary but it sucks when you ding a injector tip, there goes another $300.00. Have a work bench cleared off and cleaned, keep the valve train and injectors orginized according to there respective cylinders. We built a lifting arm for the heads but they can be removed with a cherry picker or just a good buddy. Once the heads are off the cleaning begins. We use 3m finger discs (green) to initially clean off the crud. It usually goes by fairly easy unless the head gaskets where blowen for awhile then your going to have to deal with some pitting. Once the deck and head surfaces have been cleaned it's time to check for warping. Use a quality straight edge and take plenty of measurements, nows the time to find a problem if there is one. I will attach a document from alldata that will show tolerances and torque sequences. Not sure if it will work or not but if anybody wants the page I can fax it. From there it's just reassembly, and be maticulate with the highpressure oil system and injectors, dirt and torn orings are a pain int the a**. The head stud torque will vary depending on manufacture so follow what they recommend but use Ford's sequence. One last note. Before removing the plenum, we remove the EGR valve to inspect for coolant inside the cooler, if there is any trace of coolant replace the cooler before assembly. We have had alot of these with coolant leaks. By lifting the back of the engine up, coolant will roll forward so it is visible through the EGR hole once the EGR is removed. Hope this helps, any questions give me a ring I'd be more than happy to help assist if I can.
http://www.alldatapro.com/alldata/PR...54590/34855099
gosperformance is offline
post #6 of 10 (permalink) Old 01-09-2008, 07:04 PM
South Atlanta white trash
Doodie's Avatar
Cool thread
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #7 of 10 (permalink) Old 01-10-2008, 02:54 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
The alldata link didn't work. It needs a username and password. Not to derail or anything. Just trying to help out. Cool thread though.
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #8 of 10 (permalink) Old 01-18-2008, 08:39 AM
Broke's Avatar
In my personal opinion,I think pulling the cab is the easiest way to do head gaskets on 6.0.I pull the cabs to pull engines now.I have only pulled one out through the front and it sucked.
96 F-350 CC 4x4 (Truck on hold due to move
Shackle extentions, SD turbo
35" BFG"S, fuel system
Mild Trans work, 01 HPOP
Chip,Guages,Exhaust
Broke is offline
post #9 of 10 (permalink) Old 01-18-2008, 01:51 PM
Sponsor
Logan21SV's Avatar
I would rather pull the cab, even on the 7.3s it makes life easier. Deadblow and I have it down so well it is still cost effective. Lifted 7.3s the cab comes off for anything having to do with the heads.
CenTexDiesel.com
Logan Schneider
830-885-6500
post #10 of 10 (permalink) Old 01-18-2008, 02:00 PM
Banning Smut
PTSUPERD's Avatar
^^^^If my truck had still been on 38s.....my cab could have come off. no doubt.
PTSUPERD is offline
