More Puking Than Usual - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 08-01-2007, 04:37 PM Thread Starter
ROCKSTAR
OneTonHillBilly's Avatar
I had it serviced there 2800 miles ago and they mentioned the puking. I mentioned to the dealer today that I wanted a new cap for the bottle and said they aren't going to bother. They are willing to replace Head Gaskets Now. He said, go get the studs I want and they will do it whenever I want up to 36k miles. I have 18,900 now so I will get it done in a few weeks. I don't think it needs done but since they suggested it. I will have it done. I am all for studding the heads.
2007 F-350 SRW LARIAT OUTLAW
You must be fast 'cause you were hauling ass when I passed you!!
OneTonHillBilly is offline
post #2 of 20 (permalink) Old 08-01-2007, 04:41 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: More Puking Than Usual
Heck ya, ARP man get them done now, so when you decided to up grade more power thats one less thing you have to worry about.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 20 (permalink) Old 08-01-2007, 07:16 PM
Hate 'R Us
!!!PainTrain!!!'s Avatar
I went to the dealership also for the same reason. I was told they were not going to give me a new cap and that they would replace the gaskets and studs with only OEM stock. But they wanted to charge me 5 grand. And for 5 grand I can have it done with ARP studs and injectors.
!!!PainTrain!!! is offline
post #4 of 20 (permalink) Old 08-01-2007, 07:38 PM
How many miles...if its less than 100K, it should be on there dime!!!
LokiWolf is offline
post #5 of 20 (permalink) Old 08-01-2007, 07:43 PM
Hate 'R Us
51,376 showing on the clock. But they said since I had the tuner on there, they were not going cover anything.
post #6 of 20 (permalink) Old 08-01-2007, 08:41 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
I was thinking the same thing. If I were you I'd try a couple of different dealerships, since apparently some are cool about that kinda stuff and some aren't. I'm gonna be doing the same thing here shortly.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #7 of 20 (permalink) Old 08-01-2007, 08:59 PM
Hate 'R Us
Well the thing is, I know a dealership that would probably do it. But They are not going to install the injectors under warranty. I plan on upgrading the injectors at the same time.
post #8 of 20 (permalink) Old 08-01-2007, 10:26 PM Thread Starter
ROCKSTAR
I have to supply studs. The dealer doesn't care what I do. I stopped in today after the first post. The tech suggested the ARP which I was going to go with anyhow.
post #9 of 20 (permalink) Old 08-01-2007, 11:39 PM
imelmo's Avatar
Believe me when I tell ya, it'd be well woth it to let them do the studs and head gaskets and you install the injectors later. One requires removing the cab, one doesn't.
imelmo is offline
post #10 of 20 (permalink) Old 08-02-2007, 11:34 PM
Bill
badford350's Avatar
why do you have to pull the cab for head bolts? Ive never worked on a 6.0. but that sounds like the first motor where you have to remove the cab instead of removing the motor. but maybe thats why the 6.0 fourms are smaller than the 7.3.
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
