power steering fade. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-31-2007, 02:50 AM Thread Starter
Oil anyone?
The Oiler's Avatar
For a time now I have been experienceing a losss of steering on my truck when driving slowly or using the brakes.
Set up for the truck,
8in lift- Fabtec
Fabtec dual steering stabilizer
35x13.50/17 Irok rads
Truck weighs in at 8300 lbs
Brother has short bed with same lift hight
37x13.50R20 kumho M/Ts
Does not have steering fade that i have.
I've checked the power steering resivore and each time it is full, never had to add to it. Checked with ford tech and was told that all of them do that. That dont seem right to me because I almost hit a poll with it a few times.
Has anyone had this happen to them?
Thanks.
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
T-bars,airbags, 5in stacks
getting back on the road soon.
Now have a s366 from Swamps now.
01' xlt excursion with a 7.3
all stock for now and gets 18mpg
The Oiler is offline
post #2 of 10 (permalink) Old 12-31-2007, 06:27 PM
lott is my daddy
mxchase's Avatar
Re: power steering fade.
try bleeding the lines..you could have some air. did it do it when you had smaller tires on it?
i know on some 03s they had steering problems. my friends dad had to get a whole new system.
i'd rather be hated by 12 than carried by 6
mxchase is offline
post #3 of 10 (permalink) Old 01-01-2008, 12:30 AM
GotRox's Avatar
Good thing to know. Might explain my 03s troubles.
Mine has some problems with the steering at lower speeds, and my pump makes a lot of noise sometimes.
03 Silver F-350 Crew, 6.0L, Auto, 4x4
Straight piped, AFE dry filter, Custom leveling shackles, 315/75s BFG Muds, ProComp 16x10 1059s
GotRox is offline
post #4 of 10 (permalink) Old 01-02-2008, 12:35 AM
lott is my daddy
mxchase's Avatar
thats what happened to my friends dads 03...but he had a 7.3 03.
mxchase is offline
post #5 of 10 (permalink) Old 01-02-2008, 07:02 AM
BUFF's Avatar
8in lift- Fabtec
Thanks.
Have your steering box cheaked I had to have mine replaced with less than 2000mi. It seems that when ford redid the front end thay changed the steering box and the manufactuer (same company as GM). My truck had a bad casting and was leaking through the case yours may have an internal leak and is not keeping the preasure at low speeds.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #6 of 10 (permalink) Old 01-10-2008, 03:00 PM
SUPERIOR OFFROAD INC.'s Avatar
03 steering boxes are sh*tty the always screw up or leak after a short period of time. On those trucks you cannot ever dry steer them if you have bigger tires because they will crap out on you. Best upgrade use a 2002 or mod up to a 2005-06. Early 04 boxes are also bad. Most of them were cast bad and have internal pressure loss.
2011 6.7 yet to be ####ed with.... Yet...
SUPERIOR OFFROAD INC. is offline
post #7 of 10 (permalink) Old 01-20-2008, 06:09 PM Thread Starter
Oil anyone?
The Oiler's Avatar
Mine is an 06', should i replace the box with a new one or try getting ford to pay for it.?
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
post #8 of 10 (permalink) Old 01-21-2008, 02:31 AM
BUFF's Avatar
Thay payed for mine is your truck still under the bumper to bumper?
BUFF is offline
post #9 of 10 (permalink) Old 01-21-2008, 06:34 AM
Mr. Bob's Avatar
my 2002 has horrible steering with 35s on it.... Never had it with stock tires though
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #10 of 10 (permalink) Old 01-26-2008, 03:07 AM
Send a message via MSN to Skwurlz
my '03 has horrible walk, I am wondering if this is the issue.
It's on a 6" ProComp and some 31's.
Skwurlz is offline
