how does the extreme street tune run? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-29-2009, 01:19 AM Thread Starter
RedDog's Avatar
I just bought extreme street tune for my 2006 f-350 dually 6.0 with manual transmission, everything's stock besides the gutted cat/muffler. I was just wondering how it runs on your trucks, on my truck it has alot of lag but once it hits like 2200-2300 it takes off. Another thing is when its up in the rpms when i let off, it like has a delayed reaction and doesn't idle back down, i have to wait a few seconds after i let off the pedal to shove the clutch in to shift.
RedDog is offline
post #2 of 10 (permalink) Old 10-29-2009, 01:25 AM
BRING DA AMBALAMPS
stroke of luck's Avatar
Re: how does the extreme street tune run?
mine runs great! the street type tunes won't really kick in till around that RPM range that way normal daily driving is still managable but when you get into it...hold on!
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #3 of 10 (permalink) Old 10-29-2009, 01:42 AM
Steamfighter
Steamfighter's Avatar
My street tune is pretty good with my 6 speed , but i found that if you just roll into the throttle smooth , it reacts better than mashing it to the floor . Don't notice any carry over or delay after getting off the throttle .
2006 F350 6 wheeler. some mods done thanks to First Coast Diesel Performance , but more to come!! .
Steamfitter local 602 Washington D.C.
2005 F250 OVERLOADED WORK HOSS
Steamfighter is offline
post #4 of 10 (permalink) Old 10-29-2009, 02:11 AM Thread Starter
RedDog's Avatar
yea but I ran the canned performance tune that my SF3 came with and that tune was great for low end power, it pulled pretty hard and had almost no lag but it had a issue in the upper rpm with it fading in and out so i had Eric make me up some custom tunes. but i am not sure if i like all the lag, especially for pulling out on hills and what not, i don't like to slip the clutch to hard and the canned performance tune i could pretty much not even give it gas and let the clutch out normal. Also another thing, I don't have an exhaust temp gauge yet, do I have to worry bout exhaust temps getting to hot, i am not hauling anything with it and if i do i am turning it down to the tow tune i have. Like i said I have gutted cat/muffler. Thanks
RedDog is offline
post #5 of 10 (permalink) Old 11-06-2009, 12:28 AM
Steamfighter
Mines an 06 350 dually manual w/ 4:10's Erics street tune runs lower egts than the agg tow and stock. (just truck not towing) Haven't towed any thing heavy yet to see how egts compare. I would recommend getting an insight with an egt probe or some gauges though.
post #6 of 10 (permalink) Old 11-06-2009, 12:50 AM
I make smut cry
RedDog, Where ya from?
Powerstroked162 is offline
post #7 of 10 (permalink) Old 11-06-2009, 01:02 AM
fordpowerf450's Avatar
unless you got some way good tuning witch is hard to fine 6.0's have horrible lag. mine always did stock and tuned. a full turbo back pipe would help out with the lag a little though.i always had guages and unless i tuned it up pretty high and got into never had a problem. i towed 16k with it to... an egt gauge is a good idea though just to be safe. with all i herd about 6.0's i never let my egts get over 1290. alot of people go higher than that and its okay to but i always liked being safe with the 6.0.
08 6.4 cc/lb.
2006 6.0 just stock..
1960 f100, 12v project.
fordpowerf450 is offline
post #8 of 10 (permalink) Old 11-06-2009, 01:28 AM
SamW's Avatar
runs great. innovative tuning is the best out there...
2006 F250 CCSB
6.
SamW is offline
post #9 of 10 (permalink) Old 11-06-2009, 01:50 AM
Send a message via AIM to JohnT
I love the way my extreme street runs. It has a little bit of lag, but once it lites, hold on.
JohnT is offline
post #10 of 10 (permalink) Old 11-06-2009, 06:51 PM
burning mine saving yours
RocknRoll's Avatar
Well i figured it was time to try Innovatives tunes out, ordered Xtreme, Street, and a Tow tune. Can't wait until i get home off shift, the drive home should be fun
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
RocknRoll is offline
