7.3 trubo on a 6.0????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-28-2009, 02:02 PM Thread Starter
<---- my shop
vader's fury's Avatar
I am a 7.3 guy but i have a buddy with a 05 6.0 and was wondering if a drop-in turbo for a 7.3 would fit on a 6.0. I have one in my shop and his turbo just ate itself. Thanks
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #2 of 8 (permalink) Old 10-28-2009, 03:39 PM
motoxracer42's Avatar
Re: 7.3 trubo on a 6.0?????
it will never spool. that housing is huge for a 6.0. probably wouldnt spool till like 2500 rpm or more. get another 6.0 turbo
06 crew cab
06 reg cab
motoxracer42 is offline
post #3 of 8 (permalink) Old 10-28-2009, 04:06 PM
Super Hauler!
Super_Hauler's Avatar
hell no!
Super_Hauler is offline
post #4 of 8 (permalink) Old 10-28-2009, 05:38 PM Thread Starter
<---- my shop
even with a good set of injectors it wouldn't spool up? Sorry i just gotta be sure cuz he is dead set that this will work cuz one of his truck "friends" said it would be great for him.
Robert
post #5 of 8 (permalink) Old 10-28-2009, 05:56 PM
maybe with a pretty big set. still street driving would be horrible.
06 crew cab
06 reg cab
post #6 of 8 (permalink) Old 10-28-2009, 06:07 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Turbo mount is completely different. You probably couldn't even get it to mount without some serious custom fabricating. Block, manifolds, up pipes, IC plumbing, downpipe, etc... would all be custom. You might be able to use some parts off a 7.3, but not many.
Spooling a 7.3 turbo on a 6L is going to suck without a really tight housing. It's all about the mass flow rate.
The mass (matter, be it exhaust, fuel, air, etc...) is what drives the turbo. The lower displacement of the 6l means two basic things:
1. The amount of fuel / revolution to make XXXXrpm is lower than on the 7.3L.
2. The amount of air / revolution to make XXXXrpm is lower than on the 7.3L.
Combine these two things, and you see that the GT(P) 38 will not be spooled until a much higher RPM on the 6l than the 7.3.
A 'good' set of injectors won't help. All it will do is put more fuel in. Without air, all you have is a bunch of smoke and no power.
Go ARMY!
cowboy_dan is offline
post #7 of 8 (permalink) Old 10-28-2009, 07:06 PM
i just posted one for a used turbo for an 03 over in the classifieds,.....
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #8 of 8 (permalink) Old 10-28-2009, 07:36 PM Thread Starter
<---- my shop
I will let him know.
Thanks for all the good info guys Really appriciate it.
Robert
