Why liquid cool a turbo???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-19-2009, 12:54 AM Thread Starter
Extended Power's Avatar
I don't get it......
Everyone says that it takes HEAT to build the boost and to get the turbo working...
So why do some manufacturers use coolant to cool the turbo's exhaust housing?
Why would you want to put this on a 6.0L when it seems to me like it would have the same effect as an EGR cooler....WAY too hot for the coolant, coolant would flash off...blow coolant everywhere...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #2 of 9 (permalink) Old 10-19-2009, 12:59 AM
Super Hauler!
Super_Hauler's Avatar
Re: Why liquid cool a turbo????
cool air burns better.
Super_Hauler is offline
post #3 of 9 (permalink) Old 10-19-2009, 01:09 AM
beast6.0's Avatar
I think the coolant is for keeping the bearings from overheating and give them longer life
06 F-350 CC Dually 4x4
beast6.0 is offline
post #4 of 9 (permalink) Old 10-19-2009, 01:36 AM
motoxracer42's Avatar
yea its for the bearings. it doesnt cool the charge.
06 crew cab
06 reg cab
motoxracer42 is offline
post #5 of 9 (permalink) Old 10-19-2009, 01:39 AM
Don't EFN worry about it
Aljay's Avatar
Waterl cooled turbos are nothing new. Mitsubishi Heavy Industries has been doing it for years.
Tuned by T Wildman
Aljay is offline
post #6 of 9 (permalink) Old 10-19-2009, 03:49 AM
CanadianRedneck's Avatar
Yah my turbo on my sled has a water cooling jacket in the bearing housing also. Just supposed to keep bearings cooler and make the turbo last longer but I didn't hook them up because they heat up the coolant too much on a sled.
2005 F350 Crewcab 4x4 6.0L
64mm turbo, NADP race tranny, tuning by Eric at Innovative Diesel
2004 F250 4x4 6.0L
Work in progress.......
EDE heads, cam, pistons, hybrid injectors, Hypermax rods,
2 really big turbos and a whole bunch of other crap to come.....
Tuning by Innovative of course!
CanadianRedneck is offline
post #7 of 9 (permalink) Old 10-19-2009, 11:18 AM
Crazy Redneck
UNCOOL's Avatar
Caterpillar has been doing it for years.
You will mostly see this on stationary countinuos prime movers, IE gensets that HAVE to run 24/7 to provide power. The idea is that if you keep heat moving away from the center support, the bearings do last longer. The 3516 CAT genset's I worked on, had outlet maximum EGT's of 950F. They were making around 38psi boost @ full load, and I would have 4 running while making hole. Takes alot of power to run a drilling rig.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #8 of 9 (permalink) Old 10-19-2009, 12:32 PM Thread Starter
Well this is where I seen that the exhaust housings were watercooled. Then I remember seeing that some turbo's for our 6.0L's were water cooled as well, and thought it was the exhaust housing, not the center section.
post #9 of 9 (permalink) Old 10-19-2009, 12:43 PM
It's best for all turbos to be water cooled. It helps tremendously to cool the bearings, even BB. Especially on daily driven vehicles that start/stop and get a lot of heatsoaking. The center cartridge is cooled, not the in/ex housings.
Late 84 300ZX's were watercooled, and were a big improvement over previous year models since they stopped seeing turbo failures afterwards.
2003 F250 King Ranch Crew Cab FX4 6.0L
Purchased 9-10-09
Stolen 12-3-10
Texas-KR is offline
