Symptoms of a cracked block? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-12-2009, 03:42 AM Thread Starter
jdgleason's Avatar
Just that... wondering if any of you have had a cracked block, and what the symptoms are
'09 F350
-JD
jdgleason is offline
post #2 of 14 (permalink) Old 10-12-2009, 03:47 AM
Super Hauler!
Super_Hauler's Avatar
Re: Symptoms of a cracked block?
coolant and oil leaking would be a good indication! when i had cavitaion in my last block i had some issues!
Super_Hauler is offline
post #3 of 14 (permalink) Old 10-12-2009, 07:59 PM
Stroker67's Avatar
Adam at FCDP has had a broken block, im sure he will chime in.
Stroker67 is offline
post #4 of 14 (permalink) Old 10-12-2009, 09:21 PM
Proud Sponsor
Abrannan19's Avatar
mine was pressurizing the coolant system, oil temps and coolant temps were good.then it hydrolocked...
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #5 of 14 (permalink) Old 10-12-2009, 11:02 PM
Bigfoot is an OBS
cowboy_dan's Avatar
BTS had the block crack in their white race truck. The most obvious symptom was it lost a few tenths.
After a few more passes (10-30, IDK) it finally started putting coolant in the oil.
Brian said it had him puzzled for a few weeks until it finally put the coolant in the oil. He and Cale were playing with programming and other stuff trying to get those few tenths back.
New block and they were back.
Go ARMY!
cowboy_dan is offline
post #6 of 14 (permalink) Old 10-12-2009, 11:07 PM
Don't EFN worry about it
Aljay's Avatar
I had issues with big oil truck would not run with it. Oil pressure gauge was freaked out. Drove truck a month after returning home from DHRA in 07 truck had a bad vibration then one day she started leaking oiul real bad and I looked at it and thats when I saw the crack. It was running and the block casting was moving.
Tuned by T Wildman
Aljay is offline
post #7 of 14 (permalink) Old 10-12-2009, 11:43 PM
Proud Sponsor
Abrannan19's Avatar
mine was a cracked cylinder wall
Adam Brannan
Email
post #8 of 14 (permalink) Old 10-13-2009, 02:52 AM
mine was cracked cylinder wall too. took out an inj and hydro locked.....
05 LLY DMAX, EFI, AIR, FUEL, BUILT TRANS, TRACTION AND MORE!! POWERSTROKE SLEEPER SLAYER
dukcaln1 is offline
post #9 of 14 (permalink) Old 10-13-2009, 04:21 AM Thread Starter
jdgleason's Avatar
So I guess I will ask all of your opinions.... Ive got coolant going somewhere.... somewhere I can not find not out the tail pipe not into the oil and not on the ground, a shudder when the converter is locked, and motor doesnt sound the same at higher rpms. Also mileage dropped pretty drastically.
'09 F350
-JD
post #10 of 14 (permalink) Old 10-13-2009, 04:31 AM
had a bad head gasket on a car one time before. didnt look like coolant was coming out the back but it was just engouf to make all kinds of problems.
start up the truck when its cold take off the radiator cap and look for bubbles or if you squeez the top of the radiator hose and its rock hard. the coolant hose should be a little soft not rock hard.
speeddr2000 is offline
