Constant fan, overheating at idle! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-08-2009, 02:28 AM Thread Starter
RHCDIESEL's Avatar
I dont know what else to do to this truck, ive had studs 2 times, still pukes and now when towing fan kicks on constantly and even unloaded idleing will be almost in the red on the stock gauge. What are the possibilities other than gaskets again? egr? radiator? this thing is killin me
2014 f250 4x4
Icon 2.5 stage 1 with adjustable track bar
Xd badlands black machined 18x9
Toyo 36x13x18 MT
2006 F250 FX4
175/30 warren inj
Madturbo stage 1
ARP headstuds
35/12.50/18 toyo M/T
428/871 PHP Dyno
RHCDIESEL is offline
post #2 of 11 (permalink) Old 10-08-2009, 02:30 AM
Super Hauler!
Super_Hauler's Avatar
Re: Constant fan, overheating at idle!
is your radiator clogged? My 7.3 i had overheating and oil temp issues for a while until i figured wth i will just pull the radiator and see....well there was about 20lbs worth of chit in there you couldnt even see through the damn thing! Just a thought
Super_Hauler is offline
post #3 of 11 (permalink) Old 10-08-2009, 02:33 AM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Yea I would check out your radiator and oil cooler first off. Have you done anything with your EGR yet?
SMOK'N BLUE STROKER is offline
post #4 of 11 (permalink) Old 10-08-2009, 02:53 AM
If in doubt, tach it out
04 stroker's Avatar
Send a message via AIM to 04 stroker
Im not sure on all of the symptoms, but there seems to be alot of water pump failures lately. Just something to check.
2004 Ford F-350 6.0L PSD standard cab.
Fueled by Casserly, Aired by Garrett, tuned by Eric, and built by me
04 stroker is offline
post #5 of 11 (permalink) Old 10-08-2009, 03:01 AM
PSN Mega Miler
crowz's Avatar
Either borrow a infrared thermometer or buy one. Napa and several other parts stores sell them.
Using it you can find a blockage in a radiator or other parts of the cooling system pretty fast. Just look for spots that are colder than others. Drastic temp changes are signs of clogs.
Failing that it could be the thermostat, the radiator or headgaskets. Even a bad cooling fan can do it. The electric towing fans dont do much on their own and cant cool the truck by themselfs.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #6 of 11 (permalink) Old 10-08-2009, 03:07 AM Thread Starter
RHCDIESEL's Avatar
thx ill get the infared gun tomorrow and check that first!
2014 f250 4x4
Toyo 36x13x18 MT
2006 F250 FX4
175/30 warren inj
Madturbo stage 1
ARP headstuds
428/871 PHP Dyno
post #7 of 11 (permalink) Old 10-08-2009, 03:21 AM
ford_trck's Avatar
Did you check your thermostat is it working?
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
post #8 of 11 (permalink) Old 10-09-2009, 06:37 PM
Hate 'R Us
!!!PainTrain!!!'s Avatar
It's your gaskets.
Mine did the same thing. Turn the truck on, truck would over heat in about 20 seconds, you could watch the gauge peg the red and then the CEL would kick on.
Fan started to kick on while towing, then highway driving, then finally it would just stay on. Dealer told me that the gaskets were so bad that they were burnt to the heads.
Sorry for your luck.
!!!PainTrain!!! is offline
post #9 of 11 (permalink) Old 10-10-2009, 08:36 PM
Oil anyone?
The Oiler's Avatar
Could this engine be a bigger pile of chit!
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
T-bars,airbags, 5in stacks
getting back on the road soon.
Now have a s366 from Swamps now.
01' xlt excursion with a 7.3
all stock for now and gets 18mpg
The Oiler is offline
post #10 of 11 (permalink) Old 10-11-2009, 05:07 PM
Hate 'R Us
Not sure, every time I think No, it proves me wrong.
