fuel pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-02-2009, 03:34 AM Thread Starter
Just Here
dwall's Avatar
fuel pump
What would happen if someone was to run a good holley fuel pump to keep the fuel psi up.....im still trying to learn about what mods and upgrades can be done cheaply but work real well.....ive tried searchin this but any time i search it comes up no results...thanks in advance
dwall is offline
post #2 of 13 (permalink) Old 10-02-2009, 12:07 PM
Brentos's Avatar
Re: fuel pump
would you run it as a lift pump? there is no point in putting a pressure pump after the HFCM because if you psi drops it means it cant keep up (flow enough fuel through it) there for a aditional pump will do nothing. Best is to do a airdog as a pusher or the airdog 2 standalone
Brentos is offline
post #3 of 13 (permalink) Old 10-02-2009, 04:39 PM
Send a message via AIM to JohnT
Re: fuel pump
Brentos - Couldn't the holley pump be used as a pusher pump?
Dwall - are you talking about using a holley red or black pump like the cummins guys use on their trucks?
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #4 of 13 (permalink) Old 10-02-2009, 05:20 PM
Harry Callahan
Re: fuel pump
Unless you have aftermarket injectors and a need for lots of fuel, the only thing you could add by installing more/different fuel pumps is problems and less dependability.
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
post #5 of 13 (permalink) Old 10-02-2009, 10:29 PM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
Re: fuel pump
Just running a programmer with no other mods on stock injectors, you could easily lose fuel pressure and run out of fuel. Mine does it now, I lose fuel if I hold it WOT in my race tune.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
post #6 of 13 (permalink) Old 10-02-2009, 10:33 PM Thread Starter
Just Here
dwall's Avatar
Re: fuel pump
Yea was plannin on using it as a pusher
I have stock injectors for now but does the fuel psi still not fluctuate when you get on it say at a drag strip like i said im still learning and research but looks like if you keep your psi up all the time it could do nothing but help
dwall is offline
post #7 of 13 (permalink) Old 10-02-2009, 10:39 PM
06powerstroke's Avatar
Re: fuel pump
I replaced my stock pump because I was dropping to 25psi under WOT. I used a FASS, but now I am kinda worried because of all the FASS failure threads...
I don't know much about pusher pumps and how they work. Just seems like the stocker would hold it back. That is why I did the whole system...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #8 of 13 (permalink) Old 10-02-2009, 10:41 PM
Stroker67's Avatar
Re: fuel pump
Check this out, this what i plan on doing for one day.
FueLab Pump
Stroker67 is offline
post #9 of 13 (permalink) Old 10-02-2009, 10:44 PM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Re: fuel pump
I use a Fass and I maintain fuel pressure just fine, even at WOT.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #10 of 13 (permalink) Old 10-02-2009, 11:02 PM
Re: fuel pump
FueLab Pump
Do you use that as pusher, or does that replace the stock pump...
