how hard, - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-01-2009, 02:24 AM Thread Starter
rider2xtreme93's Avatar
Send a message via AIM to rider2xtreme93
how hard,
how hard is it to install a downpipe on a 6.0? my cousin just got one for his truck, he has a silverline exhaust but jsut got the downpipe
rider2xtreme93 is offline
post #2 of 14 (permalink) Old 10-01-2009, 02:29 AM
Young'n
powerstrokeracing's Avatar
Re: how hard,
ive done a few, not to bad at all, a lot easier than the OBS
powerstrokeracing is offline
post #3 of 14 (permalink) Old 10-01-2009, 02:31 AM
SamW's Avatar
Re: how hard,
installing the new one is not the problem...its a pita to get the old downpipe off.
2006 F250 CCSB
6.
SamW is offline
post #4 of 14 (permalink) Old 10-01-2009, 02:45 AM
I dont know
Re: how hard,
Not hard at all.
o4 RC six speed.
6.0 six speed is offline
post #5 of 14 (permalink) Old 10-01-2009, 02:00 PM
Wondering what if
123rday68's Avatar
Re: how hard,
Wasn't tough to change out. I just had to readjust so it didn't vibrate up next to the fire wall. Also somehow I broke the bolt holding the downpipe to turbo clamp. Apparantly overtorqued. Anyway the friend helping me out, (two sets of hands make it easier) welded it back up and I was in buisness.
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #6 of 14 (permalink) Old 10-01-2009, 06:01 PM
Re: how hard,
not hard at all my best advice is what i did and cut the stock down where i could pull one piece from out of the hood and the other fell right out
05 white f250 with innovative tuned sct,and 4 inch straight pipe,and 20" black moto metal 951s and 33 mud grapplers
dieselfuel22 is offline
post #7 of 14 (permalink) Old 10-02-2009, 12:42 AM
bluemountianpowerstroke60's Avatar
Re: how hard,
if you got a pit or a lift drop the trans cross member and let the engine tilt down then you will be able to drop the pipe down and give it a half turn and it will drop right out,,almost all of the new ones ar 2 pice so they go in easy
nwhen you are done make sure the intake and air filter are still hooked up, the stock one tends to pop out when you tilt the engine to hard
bluemountianpowerstroke60 is offline
post #8 of 14 (permalink) Old 10-03-2009, 07:16 AM
hypersnyper694788's Avatar
Re: how hard,
Thats how i plan on doing mine so
x2
06' F-250 CC SRW 4x4, 6" fabtech lift, bilstien 5100 shocks, 4" MBRP TB no cat, ARP studs, 2 JL audio 10" W0, 20x12 weld cheyenne 8's, 35x13.50x20 Mickey Thompson Baja ATZ
BNIB 6.0 head with all related hardware, straight from FORD. For Sale PM me offers
hypersnyper694788 is offline
post #9 of 14 (permalink) Old 10-05-2009, 03:09 AM Thread Starter
Re: how hard,
my cuz did it already without a lift or pit. he said taking the stock dp out was harder the getting the new one on and bolted up
post #10 of 14 (permalink) Old 10-06-2009, 01:51 AM
Re: how hard,
Did one on an '05 the other day and as mentioned above; either cut it in to two pieces or remove the tranny crossmember. He saw a 100 degree EGT drop between the OEM and the new 3 1/2" dp.
Anyone ever use a 4" one? I would imagine you would have to hammerize it to keep it from rubbing.??
Tammac is offline
